1969 Thunderbird - Page 2 - Ford Truck Enthusiasts Forums
1969 Thunderbird
Old 12-20-2010, 06:29 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
Bill makes some really valid points on the electronics/ vacuum operated systems.
I don't plan to even try to rebuild these to original. Electric solenoids for the door locks and trunk release are the only way to go and are an easy upgrade. I may have to keep it for he headlight doors but am looking into electric options also.
I really would also like to retrofit the hydraulic wipers to electric.
I do not plan to make a correct restoration, but an updated cruiser.
Bill, do you know if the 70 birds were electric wipers and may work?
I have read the the 70's were basically very similar to the 69's but with different front end metal among other changes.
Old 12-20-2010, 06:36 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
When the '67 Birds came out, they offered "rolling door locks." When the vehicles reached 7-10 MPH, all the doors locked automatically.
"Who goofed?' 'I've got to know!" Howard Cosell to Dandy Don Meredith on Monday Night Football.
Heads rolled in Ford's engineering staff because the idiots forgot about car washes. Back then, car washes had a device that spun the wheels to wash the white wall tires.
When the rear wheels were spun, the doors locked...and since the keys were usually in the ignitions...when the cars rolled out, the people were SOL!
It wasn't too long before Ford sent out a 'Campaign' bulletin to dis-connect the damn things.
1967/71 T-B electronic crap (most shared with 1969/71 Mark III's-excepting the gawd awful sequential turn signal jazz) is pretty much the same.
If you have A.T.C. I pity you. A.T.C. = Automatic Temperature Control...it didn't work worth a damn when these cars were new, so it prolly doesn't work today.
No ATC = No heater or A/C.
Old 12-20-2010, 08:35 PM
Sevillian273's Avatar
Sevillian273 Sevillian273 is offline
Sevillian273 is starting off with a positive reputation.
Hydraulic wipers?! So THATS why there are power steering lines running into the firewall.... What were they thinking?
+1 on the vacuum stuff... nothing works on mine. I have thought about using a electric exhaust cut-out controller for the head lights. Or just cutting out the metal frame and having them shine through the grilles.
Titanium headers meborder Exhaust Systems 2 11-05-2014 07:36 AM
Looking a 130 AMP 3G Alternator Captbs32 1978 - 1996 Big Bronco 22 04-27-2012 09:52 PM
what do you think fordguy101 General Automotive Discussion 8 10-22-2004 08:44 PM
Need 390 engine tag deciphered Purely Ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 11-28-2003 04:26 PM
Need engine id help? sixte1f100 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-24-2001 07:46 PM
Tags
1969, 32, 69, codes, craigslist, desirable, differental, engine, ford, parts, sevillian273, svt, tbird, thunderbird, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
