Abs Light on After replacing my unit bearings
Old 12-17-2010, 08:39 PM
pjnadon's Avatar
pjnadon
pjnadon is offline
A Few months ago I replaced my unit bearings I did the LF first and had no Problems a week later I did my RF unit bearing and ever since I have had My ABS light on A/E has a DTC C1145 speed sensor RF input circuit failure. I have tried pluging in my old speed sensors from the old unit bearings and i still get the same Any suggestions on where I start to diagnose this problem
Old 12-17-2010, 09:21 PM
mueckster's Avatar
mueckster
mueckster is offline
Do you have an analog or digital volt-ohm meter? Put it on the lowest AC voltage setting and place the leads on the terminals of the sensor wire. I have used paper clips to access the terminals. You should see a rise and fall in voltage generated by the sensor when the wheel is raised and spun rapidly. This would indicate the sensor and exciter ring are ok. Check for resistance across the chassis end of the sensor wiring connector for an open or ground.
Old 12-19-2010, 11:06 AM
pjnadon's Avatar
pjnadon
pjnadon is offline
Thanks I did exactly that. the new sensor was no good I also checked for resistance on the new sensor and it was at 0. where as the old one gave me a reading.
Old 12-19-2010, 11:17 AM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
yep willing to bet the sensor is bad out of the package......
Old 12-19-2010, 05:17 PM
pjnadon's Avatar
pjnadon
pjnadon is offline
Yup it was I thought I might of broken a wire when i unpluged it Glad I thought to keep the old ones
Old 12-19-2010, 05:24 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Great test tip Roland. Reps to you.
Old 12-19-2010, 09:57 PM
mueckster's Avatar
mueckster
Thanks Robin. I use this test method all the time at work. The exciter rings get dirty and the sensors get out of adjustment on our company OTR trucks & trailers and dump trucks. Once I read codes to determine which wheel it is and fix it, I recheck it with the meter to verify it's all good again.
Old 10-17-2011, 11:51 AM
TchTchr's Avatar
TchTchr
TchTchr is offline
Is there a way to clean the rings and adjust the sensor? Or, is it just an R&R job. The sensor assemby is pretty pricey for the left and right front sides.
Thanks
Y2KW57
30
10-26-2020 11:33 PM
ReBilld
Crossovers
03-30-2018 07:08 PM
M3talz
09-08-2015 01:05 AM
jaoneill
Escape & Escape Hybrid
07-19-2013 04:14 PM
RDY4MUD
1997 - 2003 F150
07-05-2013 07:02 PM
Quick Reply: Abs Light on After replacing my unit bearings
