Testing ABS wheel Sensor ABS Light on - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-17-2010, 09:17 PM
pjnadon's Avatar
pjnadon pjnadon is offline
pjnadon is starting off with a positive reputation.
Does anyone know where to start checking the harness to my ABS wheel sensor. I changed my unit bearing a month ago Started with left side one week .had no problems The next week I changed the right side from then on my abs light stays on A/E says c1145Speed sensor RF input circuit failure. I have tried using my other sensors from the old unit bearings but it doesnt help
Old 12-17-2010, 10:43 PM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
You can disconnect the sensor wire and do a continuity check at the ABS module. That will at least tell you the wires are good. If it worked before I would think it isn't damaged.
Old 12-17-2010, 11:08 PM
pjnadon's Avatar
Ok I will try that is the ABS Module under the dash? It worked up until I unpluged the the sensor to change the unt bearing I dont Know if I broke a wire when I unpuged it or if the wheel sensor in the new unit bearing was no good
Old 12-17-2010, 11:24 PM
I would start by looking at the connector pins at the sensor, you may have pushed one back in the truck side connector.
Old 12-17-2010, 11:33 PM
pjnadon's Avatar
I checked that I even removed the pins from the connector and pluged them in directly to the sensor
Old 12-18-2010, 12:30 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Did you ohm out each sensor to see how they compare?
Old 12-18-2010, 12:33 AM
pjnadon's Avatar
Quote:
No not yet I have to get a meter tomorrow
Old 12-18-2010, 07:58 AM
There may also be a chance that the new unit bearing is somehow defective and the trigger is not correct. You may want to pull the sensor out and try to look in the hole. If you have the old one still you can compare what you see.
Old 12-18-2010, 04:00 PM
c125bob's Avatar
c125bob c125bob is offline
Buy American
c125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputationc125bob has a superb reputation
Check the wires under the wheel wells carefully. I had a "bad" place on a wire that was in a hard to see place. Actually, something had nicked it and it was about in 2 pieces. Spliced the wire and was back in business. I hope yours is something simple like that. Good luck and keep us posted.
Old 12-19-2010, 01:42 AM
pjnadon's Avatar
Ok thanxs Guys I figured it out The sensor in the new unit bearing was no good. I used my new meter and OHM the sensor and got nothing so I used one of my old sensor and it all works now. Now I guess on to beating out Ball joints.
Old 12-19-2010, 08:23 AM
Good deal! Glad you got it figured out.
Old 12-19-2010, 11:11 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Quote:
In Post #1 you indicated that you had already tried the sensors from your old hubs, and that it didn't give you different results.
What happened this time to cause one of them to work?
Pop
Old 12-19-2010, 11:58 AM
pjnadon's Avatar
When i tried the old sensors they where in the old unit bearings I pluged it into the truck then spun the bearings as fast as I could which didnt reset the abs light. It wasnt untill i checked the sensor with a multi meter on the lowest AC voltage setting there was a rise and fall in voltage generated by the sensor when the bearing is spun rapidly on the old one and not the new one and when I checked for ressitance the new on showed 0 and the old sensor gave me a reading. so I removed the sensor from the new unit bearing and replaced it with the used one put it all back toghter and went for a drive the abs light stayed on untill I got to a certain speed then it went out. I guess when I was spining the bearing by hand it wasnt fast enough to reset the abs light.
ABS Trouble edsheridan Excursion - King of SUVs 1 08-25-2014 03:39 PM
Torque Converter Unlocking - Wheel Speed Sensors & ABS Discussion Layson 1999 - 2003 7.3L Power Stroke Diesel 29 06-04-2013 01:27 PM
ABS sensors part numbers. Snuggyworm 6.0L Power Stroke Diesel 11 12-06-2012 09:50 PM
Abs Light on After replacing my unit bearings pjnadon 1999 - 2003 7.3L Power Stroke Diesel 7 10-17-2011 12:51 PM
Need to replace my unit bearing or wheel hub bearing? rbsample 1999 - 2003 7.3L Power Stroke Diesel 4 03-25-2011 06:04 PM
Tags
8lug, abs, diesel, dually, f150, f250, f350, ford, hubcentric, inbetween, light, ohms, reading, sensor, sensors, spacer, tranny, truck, tst, wheel, wheelcentric
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
