47 G series 6 cyl oil issue
Old 12-17-2010, 07:57 PM
frids47's Avatar
frids47
frids47 is offline
Hi folks, Although I have not posted, I have been reading for quite a while. Its been a while though. Anyway, I am now in the midst of the resto of my 47, which was my dads and grandfathers. I drove it in high school in the early 70s which is when it was parked . The 6 cyl was rebuilt. Upon start up no oil pressure. If I back feed it throught the pressure guage port, its 100%. shut it down 20 minutes and it wont pick up. I pulled the pump and had a expert look at it. He thought the gasket was possibly damaged when installed. I cut a new one since i could not find one and has the same problem. The pump has new gears in it also. Does anyone know about these pumps. It is a g series which has the distributor on the lower right front of the engine, the pump housing is also the front main bearing block. I checked the relief valve on the side and everything seems fine, as it was also new. Im at a loss and would like to keep the truck original, but a flathead 8 is not out of the question. I wil never sell it so value is not an issue. Any thoughts??
Old 12-23-2010, 10:33 PM
Carlene's Avatar
Carlene
Carlene is offline
Admom
Hi Frids47. I posted a link to this down in the Flathead Forum. Hopefully one of the guys there can help you out. Be patient though, it is the holidays.
Merry Christmas and please post some pictures.
SCFlareside
350
09-19-2019 02:29 PM
jskeith47
07-11-2015 11:01 AM
schiff94
03-06-2015 07:34 AM
COMPLIT1107
Projects
353
01-22-2015 10:08 PM
2004_6.0 powerstroke
10-21-2014 08:52 PM
Quick Reply: 47 G series 6 cyl oil issue
