ECM FOR 99 F350 DIESEL
I think normally you want to match up the pcm/ecm code. Here is a list: PCM Codes - 1994-1997 Power Stroke FAQ
I don't know enough to give advice on which one will work but maybe someone else can help.
Ok, my 99 is an early 99 and in regards to your statement "if they are both fed emissions," I thought all vehicles needed to be, if there is a possibility one or both are not, how would I know?? Thanks for your help.
Thanks, Robin.
If you have a DPC-401 box (AWA_ pcm code or something similar), you can replace it with a DPC-421 box (DAC_) with no problems. You can go the other way too, but on a manual truck, you will simply run into a check engine light due to a P0107 (BARO sensor) code.
These are 49-state PCM codes.
Thanks, Robin.
Edit: What is the PCM Code? Just curious.
Edit: Never mind. Went to my list and it is a AWA5.
1999 - AWA5 - 9DTM AGD - DPC 401 - F81F AG - 7.3L F-250/350 DIESEL - MANUAL - SERV FIX* 49S COLD WTR -VIAF3G7
The WTR stands for weather, not water. The PCM has a slightly different program to enchance cold weather performance. Most likely an emmisions re-calibration.
kennyr
07-09-2011 11:25 PM
