You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
So as of this morning my 07 Navi does not want to allow the shifter to go into the park position. Because if this I now have to leave the truck in Neutral and leave the key inside of it I can still start in neutral and it drives fine I just can't get into park when I stop.
A few days ago I was having issues getting the key out of the ignition cylinder after I turned the truck off (in park) so I figure its probably related somehow.
I searched and found some threads pointing to the shift interlock solenoid when it wont allow the shifter OUT of park, does the same apply to getting INTO park as well? does anyone know where it's located or how much/hard it is to fix?
Get under the vehicle and check the linkage to see if it has slipped for some reason.
[IMG][/IMG]
Block the vehicle so that it can not move.
Remove the yellow clip from the shift arm (right center of photo) and move the arm to the park indent.
Move the shifter in the cab to the park position.
Replace the clip on the shift arm.
__________________
2001 E-350SD V10 Triton 3.73LS, ROTW 01/02/10
2008 F-150 FX2 Sport 5.4L 3.73LS Scab 145" Wb; '05 & '07 Taurus SEL's
Bryan L. Unique Collision Center Towing & Wreck Recovery Specialist
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
IRT Shorebird's reply above - DO NOT HAVE THE MOTOR RUNNING!
B/R,
Randy
Sometimes the most obvious is the least obvious. Kind of like the guy who turned on the cruise control in his motor home and then got up and went to the back bathroom.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
