57 312Y block intake manifold
Old 12-17-2010, 05:50 PM
46yblock's Avatar
46yblock
46yblock is offline
Tomget, we will hope your measurement was wrong. If you end up taking the heads off, it is a lot easier to do the measurement. You can then do each end, or all four tabs located on the side. Almost never are all four the exact thickness. Not sure which method is best: average all four, average the ends, or just go with either front or rear measurement. Maybe someone else has a suggestion there.
I had my intake flange milled .046 in. due to head and deck material removal.
That completely removed the upper part of the flange, and actually just began machining away the rocker cover gasket rail.
The motor had a net loss of .042 in.(.035 off 113s and .028 off deck), so the "Books" called for .058 flange mill. Guys on y's forever said to just take off the same as the net loss, .042. So I just went a little higher. Good thing. It looks to me like much more than .050 off of flange is a no go.
Old 12-17-2010, 10:00 PM
Tomget's Avatar
Tomget
Tomget is offline
Thanks 46Yblock
Spktyr
12-16-2016 10:18 PM
papabills54
11-07-2016 02:26 PM
cordts
06-28-2015 05:33 PM
whale15
1983 - 2012 Ranger & B-Series
05-16-2015 06:22 PM
Tomget
03-17-2011 12:50 AM
Quick Reply: 57 312Y block intake manifold
