Found two numbers for adapter (2041 & 2044). Don't know which is right to use for 2150 Motorcraft to OE log intake, or if either is correct at all? Help? Thanks
Neither will work very well. Even getting rid of the restrictive 1bbl carb won't help with the restrictive intake. The hole is still only ~1.75"-2" diameter.......
