Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-16-2010, 06:28 PM
dropper's Avatar
dropper dropper is offline
Garage is empty, add now
dropper is starting off with a positive reputation.
smoking can't figure it out
I have a 2.3 in a Ranger 4x4
It runs rough and smokes gray pretty heavy;
then it will smooth out for a minute, the smoke will clear up and the vacuum gauge will read normal.
Then it goes back to running rough and smoking.
My check engine light doesn't work but when I pull the codes with an analog meter ( I let a buddy use my scanner, now he is nowhere to be found) the best I can tell all it's showing is EGR which is disconnected because I added a header.
Carbon fouled plugs
rough idle
fuel in oil, a little over full line
good compression
good fpr on the rail
good fuel pressure
fuel pressure leaks to 0 in about 5 min (pretty sure its the pump I'll know in a day or two)
vacuum gauge flutters around 12-14
I swapped out the upper/lower intake, fuel rail, throttle body from an extra motor I have. Nothing changed
New fuel filter, plugs, wires, cap, o2 sensor
I'm really leaning towards timing but I'm not sure where to start diagnosing.
This truck is my toy/woods truck but I'm about to try and sell my house and it really doesn't add to the aesthetics of the place all tore down in my garage.
Any advice would be much appreciated
__________________
1991 F150 4x4 302 E4OD
  #2 (permalink)
Old 01-14-2011, 01:35 PM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
If it is an automatic, check for leakage at the modulator.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Tags
23, 302, 64l, cylinder, engine, ford, rough, runnin, runs, smoking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
