Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 12-16-2010, 01:52 PM
wjminc wjminc is offline
Garage is empty, add now
wjminc is starting off with a positive reputation.
Wire fog lights to aux dash switch
I have a 2008 F250 Super Duty with the Lariat package.
What I would like to do is have the fog lights controled by one of the aux panel switchs.
I have the panel wiring layout for one of your other threads. What I need to know is what wires I need to diconnect and which switch (amp) should I use.
Thank you,
William Moore
  #2 (permalink)
Old 12-16-2010, 02:34 PM
Wagion's Avatar
Wagion Wagion is offline
2008 Ford F-350
My Garage
Wagion has a very good reputation on FTE.Wagion has a very good reputation on FTE.Wagion has a very good reputation on FTE.
If I was going to do this I would go buy new bulb plugs that fit the fog lights and wire them to a new 8 gauge or heavier wire from the positive side of the battery with a fuse right at battery to a relay then run the wire from the lowest amp upfitter switch you have open to the relay and ground the relay as close as possible to the relay. This way you are getting the most power possible right to the lights you could even switch to a brighter bulb.
__________________
2008, F350, Regular Cab, XLT, 4x4 Manual T-Case and Hubs, 6.8L V10, 6 Speed Z/F56-650, 4.10LS, Tires LT275170R18E, Built April 16, 2008
Factory Specs 362HP, 415CI, 457ft/lbs, 3812lbs payload, 12,500lbs towing
No Replacement For Displacement
  #3 (permalink)
Old 12-16-2010, 08:51 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
You won't need 8 awg wire. 14 or 12 awg is sufficient. I believe the fogs are aprox. 45 watts each. but if i assume 55 watts @ 12V or 13.8 = ~9 Amps.
If you decided to use a higher wattage bulb you may want to consider the 12 awg but keep into account the housing/lens may not handle the excessive heat.
Waigon's idea is good to keep them isolated from your existing system so they won't cause any issues and you can easily return to the stock system.
I'm using (mine are OEM aftermarket with independent wiring to a relay/switch)14 awg stranded THHN which has a 600v insulation and 90deg.C temp. rating and is gas/oil resistant. The 14 awg will safetly handle about 15 amps. The relays you can get at any automotive store.
__________________
"QUALITY IS BUILT-IN , NOT ADDED"
"06" F-250 XLT/SC/LB/FX4/5.4L/ 6-SPD man.
man.transfer & hubs/HD service front springs/rear swaybar/Line-X/"BLACK"
"04" Escape Limited/"BLACK"
"00" Mustang V6/"BLACK"
"71" Bronco, 302, "BLACK/RED"
"67" Fairlane 500 Conv./289 HI-PO/"RED"
Ohh Ya Almost Forgot-"96" Nissan Pathfinder/"BLACK"
  #4 (permalink)
Old 12-16-2010, 11:34 PM
LaredoF350's Avatar
LaredoF350 LaredoF350 is offline
LaredoF350 has a good reputation on FTE.LaredoF350 has a good reputation on FTE.LaredoF350 has a good reputation on FTE.
On my 2003 I had done a mod that allowed the fog lights to stay on with the high beams. Does this work on the 2008's?
__________________
2008 F-250 Lariat SRW 4x4 CC SWB ...
... KEM tuned MM / S&B / MBRP Cool Duals
... Dark Stone Metallic / Pueblo Gold
... Readylift 3.5" levelling kit
... Toyo MT 315/70/18 (bigger than 35-12.50)
BIG$HOW --«Õ¿Õ¬»
  #5 (permalink)
Old 12-16-2010, 11:36 PM
DernMooseAk DernMooseAk is offline
DernMooseAk is starting off with a positive reputation.
If the wiring is the same as the 05-07. there is a factory break/splice on the frame in front drivers wheel well. You could tap in there.
I have factory fogs to my aux switch. The Aux switches already have relays. Owners manual tells you the relay amps per switch.
__________________
2006 F250 V10 Supercab 4x4
  #6 (permalink)
Old 12-20-2010, 11:15 AM
Wagion's Avatar
2008 Ford F-350
My Garage
Quote:
NO! which really bummed me out. Someone on here using a wiring schematic figured out how to do it but it is much more involved then cutting one wire and grounding it. Your best bet is to buy a Bright Box. I may try the suggested way on here after truck is out of warranty but I might just do like the OP said and hook fogs up to a switch.
Link to 2008 for on with High beam
http://www.ford-trucks.com/forums/58...ml#post4685352
__________________
  #7 (permalink)
Old 04-13-2011, 09:11 PM
01EX 01EX is offline
01EX is gaining momentum as a positive member of FTE.
subscribing
__________________
Powder
PSD, 4X4,Limited,Dp-5,Gauges,S+B,3.5 Aero Turbine insert,Sonnex/Tricum Kit,203*, AIH Delete,Mile Marker,Hellwig
Spare long block, Steel rods
  #8 (permalink)
Old 04-13-2011, 11:14 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 01EX View Post
subscribing
Click the image to open in full size.
__________________
Ford trucks + Blizzard plows = Happy business owner!
05 F350 pickup V10, 03 F350 flatbed V10, 03 F550 V10, 01 F250 5.4, 97 F150 4.6, 2011 Subaru Outback
  #9 (permalink)
Old 04-15-2011, 12:52 AM
Thanks
wizardsr
__________________
Powder
Tags
aux, auxiliary, dash, diagram, f150, f250, f350, fog, ford, lights, location, panel, switch, switches, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
