You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have installed those exhaust systems you get with all the bends complete: You just cut off the old system with a saw and slip on and clamp...
Trouble is, I was helping a friend way up north who had a shop, and I don't know where he got the exhaust systems.
Does anyone know where I can get a whole system like this, for cheap? I want to install myself, and don't have the tools for mandrel bending... My wife's little import car is needing exhaust badly, the whole system including flexpipe, and we can't afford the $300+ for a shop to do it...
Can anyone make a recommendation?
Mark
I'm not sure if it will work or not... What part of the system is it?
I need from the front of the flex pipe back to just behind the resonator... (If I keep the resonator!)
Mark
Is it just a long straight piece of pipe, then? I would have to check and see if my car has any bends in front...
Walker makes all these bolt-on systems? I am hoping for the quick slip-on route, but will have to make due if I can't afford that...
Mark
A bend over the axle? You mean the pipe is long enough to go from the engine to the back? Hmmm. A picture would say a lot...
Mine is a fwd, but the pipe over the rear control arm is newer, so maybe there is enough pipe... then maybe all I would need is the flexpipe? I have seen them at Partsource and they look VERY similar to the one on the car...
If it works out and might fit, how much do you want for it, Dennis?
Mark
