1994 F150 2wd air bag light flashes
[updated:LAST EDITED ON 01-15-03 AT 09:30 PM (EST)]Hey thanks for the help and the web site link. I had bought another steering wheel with airbag thinking that it would have the parts I need. I only paid 20 bucks for it so it wasn't a big loss. I guess the clock spring is in the column below the wheel or is it below the airbag in the wheel? Thanks again for the help.
Dennis
Dennis
[updated:LAST EDITED ON 01-15-03 AT 10:26 PM (EST)]The clock spring is on the column, but you should be able to find ALL that info on that site. Here are some random pics, but there are a couple that apply to your column:
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=66912
Airbag flashes 41 code
Okay guys I guess this indicates RH front sensor problem. Replaced clockspring, checked both front sensor connectors for continuity.
I then disconnected each front sensor and code still flashes code 41. I expected it to flash code 42 when I removed the LH sensor but this didn't show.
I then switched each sensor ie LH to RH and still flashes code 41.
I did notice that I have no buzzer sounding to indicate a problem, from what I've read here the buzzer is in the airbag module itself? When I turn off the ignition I get 3 beeps through the car radio speakers , but I'm thinking this is just the radio? Just bought this truck so still trying to figure it out.
I guess my question is, is there possibly a problem with the wiring from the RH sensor back to the airbag module?
If anyone has a wiring diagram for this, it would be really helpful, and also any other suggestions to fix this would be appreciated.
