Virtual gauage monitor vs. actual gauges
Hey all, im looking for some help from those with experience. I have a 04 f350 CC LB completely stock. The truck runs great, but I know I'm in the need of gauges to help keep an eye on things before they go south.
What are the pros/cons of a virtual gauge monitor, like the Edge Insight, vs. a set of real gauges?
Im leaning towards the Insight, because of the benefit of the scan tool. But what I'm not having any luck finding clearly is what can be monitored by the Insight. I know I need to monitor ECT, EOT, Trans and EGT. I believe the Insight support EGT with an optional probe.
Are there additional parameters that I should monitor which the Insight cant cover? Do the virtual gauges provide as good as quality metrics as the physical gauges? If I went with physical gauges, what are the recommended brands? Any to avoid?
BTW, this site is a great resource, but at times feels like a bit of information overload for this newbie. Im soaking up as much info as I can to fix the 6.0l weaknesses before they become issues. Thanks in advance for the help.
Cheers!
Cheers!
I have the Edge Insight w/ their exhaust probe. For the price it's pretty good, check Amazon out. The newer Edge products will allow you to add several extra sensors (ie EGT and fuel pressure) but they are more expensive. The Insight allows me to monitor parameters, read codes and reset faults. No problems so far. My logic was that I would use this for a while and if the truck doesn't melt down I would buy the newer one and move this one to another vehicle. Who knows I may find other toys that I want first!
Generally, all the ODBII plug-in monitor devices have the same capability
to display whatever sensors are available via the ODBII.
fuel pressure, Exhaust Gas Temp, and sometimes boost (depends on year maybe) require an external SENSOR.
Edit: Someone pointed out you can use MAP to calculate boost (at sea level) by subtracting 15 from whatever the MAP is:
MAP of 15 = no boost, MAP of 25 = 10 lb boost. At 10k feet, you need to figure out the offset yourself.
The insight supports connecting external sensors, so you could just use
the insight and plug in additional sensor(s) with the right setup
(I'll let other's who use it explain more if needed)
The Scangauge2 doesn't support external sensors, but can display whatever
sensors are available via the ODBII (just like insight, dashdaq, etc.)
I chose the scangauge2 because it fits neatly into the "cubby" of my Ex
where the upfitter switches go in an F250/F350 and the price was right.
You can buy the expandable probe for future sensors. I just stuck with the EGT probe only.
EGT - EAS Starter Kit w/ EGT Cable for CS and CTS (expandable)
Edit: sorry I am slow on the typing. Woodlander beat me to the punch. A good system though.
Thanks all for the input. I like the idea of the Insight + EGT probe. Looks like i'd just need to get an external gauge for fuel pressure. Even though the Edge allows for expansion it doesnt looks like it supports the fuel pressure, at least from what I can tell.
Thanks woodlander and Jetact for the pics. That helps a lot to see the different models mounted in the cab. I think the CS looks more integrated but I like the bigger screen and more display on the CTS...hmm...decisions.
on
I do have a picture of mine in my gallery in the "Beta Spartan Phalanx" album if you are interested.
Thanks Tex and Rob for the input on DashDaq. That looks like a good option too. I'm assuming to get this to work with EGT and Fuel pressure you need to add on the exhaust probe and pressure sensors, but I couldnt find on their web site where they sell the add-ons. Any sources for 3rd sensors compatible sensors?
Thanks!
Thanks!
