Common leaks?
Common leaks?
Ok my first leak is at the bottom of the radiator there are 2 fittings that have about a 3/8 inch hose connecting them to each other the fittings are leaking anyone else truck like this kinda wonder why a hose just connects 2 fittings on the bottom of the radiator??
The other leak is some flexible fuel lines on the drivers side of the truck it leaks at what appears to be a quick connect fitting probably thinking it's gonna take new hoses to fix and what is the thing under the exhaust they go to???
Sounds to me like someone bypassed the trans cooler that is in the radiator. Are the metal lines that come off the trans still there? If they are, are they going up to rubber lines that go around the radiator to the front of the radiator? If so, I hope there is a big cooler up there instead of the tiny stock cooler. If the hose that's leaking just goes from one fitting to another then I wouldn't worry about that leak, maybe just tighten them up.
Sounds like the truck has electric fuel on it and they put the fuel regular under there for some reason or another. Get a new line I guess. I have my fuel regular over on the fender.
Dtmaster2008
05-29-2013 11:49 PM
cgoservices
02-01-2013 10:58 PM
