4.9 hard starting when warm - Ford Truck Enthusiasts Forums
Old 12-15-2010, 07:46 PM
cowman435's Avatar
cowman435 cowman435 is offline
cowman435 is starting off with a positive reputation.
hi i have a 94 f150 4.9 5spd and it starts fine when cold but if i drive for awhile and it gets up to operating temperature and i shut it off it takes a lot of cranking to get it to start... any ideas what this might be?
Old 12-15-2010, 10:20 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
When it does start, does it lope or idle rough? Does it do this all the time? Is the "check engine" light on? If it does start hard next time try tapping on the IAC (idle air control) valve, see if that helps. The IAC may be going bad.
John
Old 12-15-2010, 10:30 PM
cowman435's Avatar
Quote:
John
it will sputter for awhile until i tap the gas a bit and then it idles fine and no the check engine light is not on
Old 12-15-2010, 11:06 PM
Pkupman82's Avatar
My 96 F150 with the 300 I6 did the same thing when warm or in hotter weather... never in the cold, it turned out to be the IAC. I replaced it and haven't had a problem since.
John
Old 12-15-2010, 11:09 PM
cowman435's Avatar
John
hmm ill hafta try tapping on the iac then
Old 12-16-2010, 09:03 AM
Pkupman82's Avatar
You could try that, and if that doesn't work... try taking it off and cleaning it. It's most likely carboned up inside causing the valve to stick, I'd try using carb cleaner or better yet Sea Foam.
Old 12-16-2010, 09:17 AM
cowman435's Avatar
Ok I will do that tonight then
Old 12-16-2010, 05:27 PM
cowman435's Avatar
Well I used MAF cleaner on it and WOW did it make a difference the a/c doesn't effect the engine as much and it starts beautifully when warm . Thank you so much for the tips it is greatly appreciated.
Old 12-16-2010, 11:45 PM
61UniB100's Avatar
61UniB100 61UniB100 is offline
61UniB100 is starting off with a positive reputation.
I am having the same problem with my 96 4.9. Where is the IAC? I don't have a shop book yet. Is this part expensive? Thanks in advance!
Old 12-16-2010, 11:51 PM
cowman435's Avatar
Idk about price but it's right on top of the intake and looks like a cylinder with wires coming out towards the drive side.. That's on my 94 I'd assume it the same for your 96 but not positive it has 2 bolts one on each side. 1/4 if I remember right
Old 12-16-2010, 11:54 PM
61UniB100's Avatar
I thought that was it. Thanks for the quick reply! I am going to give it a shot this weekend and see if it cures the problem.
Old 12-16-2010, 11:59 PM
cowman435's Avatar
The only thing is if your going to clean it idk how it would react to carb cleaner I thought I'd be safe and went with MAF cleaner because I didn't kno how sensitive it is.
Old 12-17-2010, 12:03 AM
61UniB100's Avatar
I will go with the MAF cleaner then. Thanks again
Old 12-17-2010, 12:06 AM
cowman435's Avatar
Not a problem glad I could be of help
Old 12-08-2013, 10:03 AM
f15olandscape's Avatar
f15olandscape f15olandscape is offline
f15olandscape has a very good reputation on FTE.f15olandscape has a very good reputation on FTE.f15olandscape has a very good reputation on FTE.f15olandscape has a very good reputation on FTE.
I know this thread is old but I came across it searching because my 1992 F150 4.9 E4OD has been doing the same thing for awhile. So yesterday I went and bought a new IAC and put it in now since its winter I wont find out until the warmer weather. But now when I put the truck in drive it idles up more than it used to and then idles back down. The old IAC defiantly had carbon in it the inside of it was total black. I rechecked everything gasket is seated right I don't believe theirs any leaks. No CEL is on either. It has gotten alittle better but it still does it. Does it take so many start cycles for the computer to re learn the new IAC? Thanks
95 4.9 swapped with a 97 5.8 won't start Wildrebel69xxxx 1987 - 1996 F150 & Larger F-Series Trucks 5 04-26-2016 05:58 PM
1995 F150 4.9l jerking and sputtering moosey78 1987 - 1996 F150 & Larger F-Series Trucks 5 02-12-2016 04:38 PM
96 F150 4.9 Will not start when hot? covocy 1987 - 1996 F150 & Larger F-Series Trucks 7 05-24-2015 07:23 PM
'95 4.9L hard cold starting cleon159 1987 - 1996 F150 & Larger F-Series Trucks 17 06-27-2011 09:26 AM
4.9l injector upgrade 95 Big Red 1987 - 1996 F150 & Larger F-Series Trucks 6 11-15-2009 09:30 AM
Tags
1984, 49, 49l, 69, 87, 91, bronco, f150, f250, ford, hard, hot, rough, start, starting, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
