4.9 hard starting when warm - Page 2 - Ford Truck Enthusiasts Forums
Old 12-08-2013, 02:19 PM
f15olandscape's Avatar
f15olandscape f15olandscape is offline
f15olandscape has a very good reputation on FTE.f15olandscape has a very good reputation on FTE.f15olandscape has a very good reputation on FTE.f15olandscape has a very good reputation on FTE.
Bump no one has any idea?
Old 12-08-2013, 03:17 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Try unhooking the battery overnight to make the computer "reboot" itself.
Old 12-08-2013, 06:26 PM
Ok thank you I will try that, its going to my mechanic to get a radiator and some other coolant leaks fixed on Tuesday, Thanks for your response. It never did it with the old IAC
95 4.9 swapped with a 97 5.8 won't start Wildrebel69xxxx 1987 - 1996 F150 & Larger F-Series Trucks 5 04-26-2016 05:58 PM
1995 F150 4.9l jerking and sputtering moosey78 1987 - 1996 F150 & Larger F-Series Trucks 5 02-12-2016 04:38 PM
96 F150 4.9 Will not start when hot? covocy 1987 - 1996 F150 & Larger F-Series Trucks 7 05-24-2015 07:23 PM
'95 4.9L hard cold starting cleon159 1987 - 1996 F150 & Larger F-Series Trucks 17 06-27-2011 09:26 AM
4.9l injector upgrade 95 Big Red 1987 - 1996 F150 & Larger F-Series Trucks 6 11-15-2009 09:30 AM
Tags
1984, 49, 49l, 69, 87, 91, bronco, f150, f250, ford, hard, hot, rough, start, starting, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
