Oil Pan Removal - Ford Truck Enthusiasts Forums
Oil Pan Removal
Old 12-15-2010, 06:32 PM
lakeman70 lakeman70 is offline
lakeman70 is starting off with a positive reputation.
Oil Pan Removal
Hello all. This may be a dumb question, but I was wanting to know if the oil pan on my 05 F350 6.0l can be removed fairly easily. Can I simply unbolt it and remove it?? I ask this question because this is my first diesel. I've removed several on gas motors in the past just need to know if the diesel is any diffrent. Thanks in advance, any input will be greatly appreciated.
Old 12-15-2010, 06:50 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
I believe you have to remove the motor mounting bolts and jack the motor up slightly.
The more experienced ones with chime in, im sure.
Old 12-15-2010, 08:19 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
unbolt engine mount nuts at frame. lift engine 2" you may wisy to remove the fan shround to prevent damage. if you dont and you break something I will laugh .
unbolt the oil pan slide it back drop the pick up tube down and let if fall in the pan then slide the pan out.
Old 12-15-2010, 09:07 PM
Thanks I had a feeling I would have to raise the motor. Was wishful thinking I wouldn't have to. I'm going to remove it because it is seeping oil. Would you recomend Ford factory gasket or is there a better aftermarket one??
Old 12-15-2010, 09:15 PM
cheezit's Avatar
ford gaskets.
make sure to place something under the motor mounts so the engine does not fall before you want it to.
Old 12-15-2010, 10:12 PM
Cheezit, really appreciate all your input. It will make things go smoother.
Thanks
Old 12-16-2010, 10:29 PM
holdendaniels holdendaniels is offline
holdendaniels is starting off with a positive reputation.
Pay attention to the bolts, they are not all the same length. There are long bolts that go in the front and rear of the oil pan.
Old 07-19-2011, 12:30 PM
greezy_jeans greezy_jeans is offline
greezy_jeans is starting off with a positive reputation.
ok guys i made a rookie mistake, mixed up the long and short bolts, forgot where the long ones go. can anyone help me with this i know front and back but i dont remember exactly.
Old 07-19-2011, 12:40 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Take a long bolt and try it in each hole hand tight. You should be able to tell which ones take the short bolt.
Old 07-19-2011, 06:13 PM
cheezit's Avatar
3 go in the front just watch the holes you put them in and 2 go in the back of the pan in the center
Old 07-20-2011, 09:49 PM
Skinner F350 Skinner F350 is offline
Skinner F350 is starting off with a positive reputation.
where did you place your jack or did you use a picker.
Old 07-20-2011, 09:53 PM
cheezit's Avatar
using a floor jack is a bit on the unsafe side... been there done that. use a block of wood under the balance. once the motor is up use something as a support under the motor mount. do not stick your fingers or hands any were they can be crushed while doing this. I use 2 large sockets wuth extensions as handles so I dont stick my hands in the wrong place.
Old 07-21-2011, 09:19 AM
sounds good. Thanks
Old 07-21-2011, 10:05 AM
69cj's Avatar
Quote:
What's the balance or am I reading this wrong?
Old 07-21-2011, 10:16 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Looking at the keyboard, I'm sure he meant Valance......
Oil pan questions andrew's64 1967 - 1972 F-100 & Larger F-Series Trucks 15 08-22-2016 12:17 AM
87 F250 4X4 6.9 DIESEL- 0 oil pressure at ilde antiqbob Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 07-30-2015 12:32 PM
oil pan removal clearance 460 1990 F-250 chincycoot 1987 - 1996 F150 & Larger F-Series Trucks 6 08-30-2013 07:47 AM
88 250 7.5 oil pan removal ch88250 1987 - 1996 F150 & Larger F-Series Trucks 5 06-12-2012 05:37 AM
New oil pan and gasket still leaks oldcoupe42 Ford Inline Six, 200, 250, 4.9L / 300 34 07-07-2010 09:10 PM
Tags
2006, 351, 60, diesel, duty, f450, ford, oil, pan, pans, powerstroke, removal, remove, removeal, replacement, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
