Front end help
That's a pretty drastic alteration, imho. Even if you can get past the mounting issue (which would be difficult), I don't know if there would be enough clearance between the axle and frame rail for any suspension movement, and your drag link would need some serious rework to not have horrendous bump-steer. These are just a couple thoughts off the top of my head, without looking at anything. I would think there's got to be a better way of lowering your truck.
Most importantly, IMO, the beam axle on top with the rounded edge would create a possibility for the axle to "roll" on its side while driving. That would mean a loss of control and could cause a major accident..... maybe not for yourself, but for the person you crash into. I suggest either removing a couple leaves for a little lowering, or fork out the cash and get a dropped axle from Mor-drop or other reputable bender.
I agree completely with the others. There is normally only a couple inches of clearance between the axle snubber on the frame and the top of the spring plate to begin with. The axle beam itself is thicker than that. You'd have essentially NO suspension travel. A dropped axle is the only way to go.
You can flip the axle but would have to C notch the frame. The guys that I have talked to that have flipped the axle did not really care for it becuase of clearance issues. Of course the guys I talked to were calling me to order a dropped axle to change it back to the bottom of the spring. Any time you use a dropped axle, change springs or lower the front end in any way always make sure your drag link from the steering pitman arm to the steering arm is level and parallel to the frame. If it is not this will more than likely give you bump steer issues.
Here's the HAMB link; it was done on a '62 F-100!
http://www.jalopyjournal.com/forum/s...ight=axle+flip
h2omotorsports
20
01-28-2009 02:36 PM
f350custom
04-23-2006 06:24 AM
