1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
serpentine belt help?
Old 12-15-2010, 12:57 PM
kennethpina's Avatar
kennethpina
kennethpina is offline
If I replace my serpentine belt should I replace the tensioner as well. I have 152,000 miles and every thing is origanal.
Old 12-15-2010, 02:44 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,074 Likes on 976 Posts
Only if it is bad......Everything else has 152k on it too, right? Are you gonna replace everything?
Old 12-15-2010, 02:56 PM
kennethpina
Yes everthing except the sparkplugs and coils are original. I started hearing a squeak comming from the belt if I gas hard and then let off real quick. So I figured It was time to replace the belt. Any other suggestions on what should be replaced? Otherwise the truck runs great!
Old 12-15-2010, 03:31 PM
bpounds's Avatar
bpounds
bpounds is online now
If the belt looked to be in good shape, without cracks or other obvious wear, but the belt still squeaked, I think I would change the tensioner. I don't like doing things twice just to try and save a buck.
Old 12-15-2010, 03:40 PM
bryyce62's Avatar
bryyce62
bryyce62 is offline
If your belt is tight, I wouldn't worry too much about a little chirp under load.
Might want to think about PCV valve, fuel filter and O2 sensors, if they're originals also.
Old 12-15-2010, 03:43 PM
Zmann's Avatar
Zmann
Zmann is offline
i would do the tensioner also if doing a belt and had that many miles
I would also store the old ones for emergency spares
Old 12-15-2010, 10:08 PM
jim6liter's Avatar
jim6liter
jim6liter is offline
If the tensioner is funcioning flawless,why change it.I had to replace mine recently.Not sure if they are the same on yours,but Ford is very proud of them on the 6.0
Old 12-16-2010, 09:22 AM
bpounds's Avatar
bpounds
Is it functioning flawlessly? The belt is squeaking.
Old 12-16-2010, 09:41 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
It's an inexpensive part, I'd just replace it. If it's making noise, you may end up with one that looked like mine did and possibly leave you on the side of the road. If the old belt is still somewhat intact, it may be worth keeping as an emergency replacement.
Missing bearings...
Old 12-16-2010, 11:44 AM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
I would suggest taking the belt off and checking all the parts. How do you know the noise come from the tensioner and not from the alternator for example?
Than old belts make very lousy spare. It would suck to put it on 2 years from now only to see it failing a mile down the road. If the old belt still has no crack, I would put it back and carry new one (with necessary tools) in the truck.
Old 12-16-2010, 12:15 PM
fordmanbrad's Avatar
fordmanbrad
fordmanbrad is offline
I would replace it, because when i goes, the belt will likely be destroyed and you will lose all of your power accessories immediately. The one on my '93 went in a parking garage and I almost ran into a wall when the power steering went out. That litte plastic thing takes alot of stress! Keep the old belt under your seat for emergency use too!
Old 12-16-2010, 12:20 PM
dkf's Avatar
dkf
dkf is offline
With 152k on the clock I'd bet money the tensioner and idler bearings are in bad shape. I pull my tensioner and idler pulleys off periodically, pull one of the seals and regrease it. Helps them last longer. The bearings can also be pressed out and replaced as they are standard size stock bearings.
Here are two pics that show the seal removal and seal removed. The bearing in the pic was smooth the grease was junk, chunky and dry.
Tensioner and Idler greased and ready to be re-installed.
Old 12-16-2010, 01:19 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Not necessarily the entire tensioner assembly, but I do replace idler pulleys by 200K miles. I'm doing mine next week!
I do inspect the tensioner for wear or slop. These seem to be just springs, no pneumatic or hydraulic dampers in it - so if spring is taut and there is no slop, I leave it.
Gates and Goodyear both make them, about $20-$25 from online retailers.
And as others mentioned, can just replace the bearings for even less.
My plan: Put the non-OE and very affordable Gates pulleys on but keep the old stock pulleys. If the Gates turn out to be sub-standard and start squeaking, then I will go to local bearing store and get new "top shelf" bearings to press into the original Ford pulleys.
cjspack
07-30-2020 11:52 PM
Justin Jones
02-11-2018 10:06 PM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
13
08-11-2013 09:01 PM
ottr1967
02-21-2007 03:26 PM
Ranger Lance
3.0L V6
05-01-2004 07:54 PM
Quick Reply: serpentine belt help?
