90 7.3 block heater ? - Ford Truck Enthusiasts Forums
Old 12-15-2010, 07:22 AM
fisheasy fisheasy is offline
fisheasy is starting off with a positive reputation.
is there a way i can check to see if my block heater is working? I had my truck plugged in for 12 hours and it still had a hard time starting. is this normal? its usually not this cold in NC and i dont usually have any problems. So i was just wondering if there is a way to make sure my block heater is working. oh and i have a new set of glow plugs in the truck so it should not be that
Old 12-15-2010, 08:52 AM
1994F2507.3L's Avatar
1994F2507.3L 1994F2507.3L is offline
1994F2507.3L is gaining momentum as a positive member of FTE.1994F2507.3L is gaining momentum as a positive member of FTE.
the easiest way to tell for me is to plug it in and when its quite put your ear down by the top of the passanger side wheel and listen you should be able to hear some stuff going on like a faint electrical noise the other way is to wait about an hour and go out and stuff ur hand back there the exhaust manifold and block on that side should be warm to the touch
Old 12-15-2010, 08:55 AM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
if your truck is starting hard with brand new GPs and the BH plugged in, you may have an air intrusion problem. Does your truck start right up after a bit of cranking, or does it just fire on a few cylinders and start up rough like. Do you see any smoke before it starts while cranking?
Old 12-15-2010, 08:59 AM
yea I can hear my block heater working about 10-12 seconds after I plug it in. Theirs also a way to test the block heater with a tester but I dont recall what the readings are supposed to be.
Old 12-15-2010, 12:26 PM
Quote:
it will run ruff for maybe 3 or 4 seconds. when it cranks up. I will spin the key for probably 10 seconds and will have to wait then do it again and again. probably 3 or 4 times. when its warm it starts right up but still runs ruff for a few seconds
Old 12-15-2010, 12:29 PM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
Yeah, just feel around where you put oil in the engine and it should be warm. My rad also warms up too when the block heater is on.
Old 12-16-2010, 06:14 AM
it must not be working bc i went out this morning and the motor is cold. |Where is the heater located and where can i get another one
Old 12-16-2010, 11:31 AM
Country_boy_2007's Avatar
Country_boy_2007 Country_boy_2007 is offline
Country_boy_2007 is gaining momentum as a positive member of FTE.
the BH is in the block pretty much right on top of the starter. just follow the cord. youll have to drain your coolent to replace it though
Old 08-16-2011, 08:26 PM
Truckermechanic Truckermechanic is offline
Truckermechanic is starting off with a positive reputation.
Thumbs up Tool for testing block heaters
JoSa Enterprises from Atkins, Iowa makes a really rugged tool that will test any block heater, it gives you a digital read out in volts, watts, and amps, normal block heater for a ford diesel will range from 700-1000 watts. Google - JoSa Enterprises Power-Block
Hope this helps!
www.josapowerblock.com
Block heater questions f100today 1994.5 - 1997 7.3L Power Stroke Diesel 13 12-09-2016 09:49 PM
Block heater not working... FarmBoyFords Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 01-05-2012 08:28 PM
block heater b_man360 Ranger & B-Series 2 12-30-2010 01:35 AM
Block Heater Question High Binder 6.0L Power Stroke Diesel 21 01-13-2010 07:17 PM
How do I know if my block heater is working? SoundBuys 1999 - 2003 7.3L Power Stroke Diesel 10 12-14-2004 04:08 AM
Tags
1992, 1994, 1997, 73, 73l, block, diesel, f250, ford, heater, heaters, idi, international, litre, located, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
