'51 Ford Truck Scary Front Suspension...Help!
1951 Ford truck, Chevy 350 engine/automatic, 72 Camaro front end.....Just got the truck....I knew it had the camaro front end but didn't notice the severity of how they accomplished it. I plan on it being a work truck some day, so i dont care to much about how the frame and engine mounting looks as long as it works good and isn't going to snap in half....Any ideas how to fix it....I was think about welding square bar higher and over the control arm then using a universal cross support with engine mounts and welding it to the square bar over the control arm...thanks for any help
Sheesh! What a mess! I'd be afraid, too. It looks like they just grafted the crossmember section only out of the Camaro into the stock frame. The way that a Camaro subframe is normally installed is to completely cut the stock frame off somewhere around the firewall and graft the GM subframe's rails into the the stock rails. The front section of the stock frame is then grafted back onto the Camaro subframe to retain the front crossmember and frame horns for mounting the core support and front bumper. Camaro subframes aren't that expensive or hard to find. If it were me, I'd research the correct way to install it, chop that mess off, and start from scratch the right way. I know that you aren't concerned about appearance, but that isn't the issue here. It's safety. I see the potential for stress risers and frame cracks all over the place on what you've got. A tiny, unseen frame crack in that area could really ruin your day if it opened up at 75 MPH on the interstate.
Well if it was me I'd ask for my money back and go buy something else that wont get you or your family killed. If that is out of the question then I would replace the frame with something that I would feel safe to sit in, let alone start and drive. Maybe find someone with a original frame or front section to graft on untill you can fix it up to your liking. I've seen some pretty shady stuff but that is just plain scary...
on
That's unbelievable. Before you start just driving to all the junk yards, give craigslist and the HAMB a shot. I've seen quite a few frames in the last couple months here and there. There are multiple search programs, but I use one called www.searchtempest.com. You can set a radius around your zip code and it will start giving you the results in a target-like fashion with the closest ones first, etc. If you can't find a complete roller chassis, I agree with everybody else. Chop that rat's nest off and start over.
