C-6 Rebuild Cost?
C-6 Rebuild Cost?
So, in my 79 f100 i have the original C-6. It leaks a little and will not shift into drive untill it warms up. Also heard this was a common problem due to some seal that shrinks or something. How much would it typiccaly cost to rebuild a c-6, if i do it myself vs. dropping the truck off and letting a garage do it? Just a stock rebuild, nothing fancy, no shift kit.....also, if i decided to paint the tranny...what color would ford have done...i was thinking just gloss black
Had my C6 rebuilt a couple of months ago. Cleaned the case, freshened up the TC, new soft parts, kevlar bands, B&M shift kit, all hard parts checked out, dyno'd to check the shift points, and hit with a coat of black paint. About a half-day's labor and $600 out the door. I had to drop the tranny myself...which was an adventure without a transmission jack and a fancy lift. A floor jack, a piece of scrap 4x4, and a C6 precariously perched on top. Not the most stable of configurations.
The best part was getting my wife to help lift the 200-lb sucker into the back of her yuppie Nissan Murano!
I'm sure. I actually budgeted for $1K to do mine... I'd consider mine about as "total makeover" as you can get, short of putting a brand new TC on it. They checked out mine (turns out the PO had already put a higher-stall TC on it), flushed it, and said it was good to go. Unless I was going to race it, they didn't recommend I buy a new TC. Refreshing to get that kind of customer service...they could have just as easily taken more of my money to give me something I didn't need/want.
Performance Torque Converters in Muscle Shoals, AL, if anyone is curious. They specialize in racing applications, but were more than happy to do business with me. Great group there. Performance Torque Converters - Performance Torque Converters
Shoot...not cheap????? How much cheaper do you want? The C6 is practially the easiest trans to rebuild. Have you priced out getting a newer trans rebuilt lately, you're looking at about double what a C6 costs. My last AOD and E4OD's were all between 12-1600 for stock rebuilds. Anyway, a C6 will run you between $6-800 for a stock rebuild at a shop, and would be about $300 in parts if you decide to tackle it.
Ford C6 C-6 Transmission Overhaul Rebuild Kit 67-96 - eBay (item 370212984647 end time Dec-30-10 13:41:39 PST)
The only tool you HAVE to have is a Clutch Spring compressor from the above site #C6T $50 the other stuff just makes it easier. You are not going to pull the clutches apart without this tool.
It is pretty easy to take a working transmission that needs a rebuild and put a kit in, the hard part is when it is not working right.
About 300$ for a stock build like everybody has said. Did mine last winter with ZERO prior experience and it was a breeeeeeze. By far the hardest part was dropping it and puting it back in as people have said, by myself, and with a floor jack. You can make a clutch spring compressor with 4 bolts, about 10 nuts, and one triangular piece of steel with holes, a barn door hinge works well. No drilling or welding required if you plan it out right.
Get an instructional DVD for your trans though, look up BadShoe productions. Nothing fancy but the guy knows every little in and out, and has alot of tips.
Go for it, and goodluck, AleX
Have you considered a reman through Autozone or Oreilly? What about a mail order C6 through Jegs, Summit, or Performance Automatic???
