Glowing exhaust manifolds
I feel for ya bro, after seeing your posts a few goofy things came to mind;
Previous owner replaced the manifold from one he found at the Trinity test site.
It'll take just a jiffy to cook hot dogs in your engine compartment.
An on board alternative to LED underbody accent lights.
I remember just prior to failure on an old CJ 5 Jeep I had one of the headers was glowing, I could only see this at night but it wasn't bright orange either, shortly thereafter a silver dollar sized hole appeared and I went to a new set of Hookers. I suppose it's time to take 'er in to the Ford garage and hopefully they'll have a current TSB and knowledge to find what truly is the culprit. Best of luck to you, sincerly.
1992 e-350 7.5 460
Long story short, my father and I are traveling cross country in our rv. We're stuck in va bc we had a faulty fuel injector that needed to be replaced. Fixed that and cleaned the rest, but when we went for a test drive we noticed the exhaust manifold glowing bright orange.
So we've replaced the:
Plugs and wires
Cap and rotor
Map
O2 sensor
Removed the cat and put a 3" exhaust
IAT sensor
Changed fuel filter
Fuel pressure regulator
Replaced vacuum lines and checked for leaks (18 in-hg with a .5 variation at idle)
Checked base timing (set at 10)
Tps read smooth resistance
Coolant temp sensor reads ok
Egr opens at low gear/rpm not wot
Replaced ignition module
We get a pinging/hesitation under heavy load
So we're towing a 24 foot car hauler and will be under load the whole way across and have no idea where to turn next. This sucks..
Thanks for any input, really, we're desperate
Plugs and wires
Cap and rotor
Map
O2 sensor
IAT sensor
Changed fuel filter
I have the same case
Firefighter6601
13
02-07-2016 04:17 PM
BuickBrian
11-02-2015 04:41 AM
