2 door convert to 3 door
1990 F-150 extended cab. I have a full bench seat and would like to convert to a third door. I have seen it done and the 3rd door latched at the top and/or bottom. I was thinking of buying a cab off of another truck from scrap, cutting/ welding the correct frame and mounting a door. Has anyone done this or can you give me pointers?
This is not impossible. I have a plan to install the roll up power rear window from a Toyota into my F150. If you have the time, tools, *****, and spirit go for it. I would love to see the results.
I was thinking about this a long time ago and was visualizing using the rear-most (3rd in this case) door of a side entry optioned van. I could be wrong but I do believe that there was such option for the 87-91(?) Econoline van. If such option does exist, the C-pillar could be used, along with the door frame.
i've looked pretty heavily into doing this to later seventies ford and i'd do it the same way. using a second cab add on to the existing door frame with the back portion like you were making on long *** door. for the back door you use the rear of the of the usual door frame as the front on a usual door with the usual super cab skin. you can use latches from a newer 3 door truck or the econoline ones would be perfect along with the opened mechanism. i don't have hinges as figured out but suicide doors have been done before plenty of times so use that same setup.
edit: oh and the econoline door and frame thing probably wouldn't work that great, not saying it couldn't be done but the van bodies are taller and don't have a lot in common with the trucks so it would look out of place. i used to have a super rusty econoline and wanted to hack off the back and add a pickup but when i looked into it more it was funny looking.
All great insight and much appreciated. I happen to have an e350 van, great body, bad transmission. I will likely use the hinges as they offer something like 170 degree opening. The doors are tall and would not quite work, or would involve a lot more metal work to fit. I am leaning toward a quarter panel of a similar cab. I am going to do more measuring and looking at body design to decide. This will be a fun project and probably one that provides a unique learning experience.
CJM8515 - I was looking to mount the hinges to the back of the cab allowing the door to open minimum 90 degrees from the cab. I am going to look at latching to the cab top and then offering the center normal latch for the forward door. I am leaving the seals out of the discussion for now but will have to make or have them molded to the door
95STEPSIDE - I am just starting the planning process, it may be this spring or early summer before I make the first cut. I will post pics through out and possibly compile a video but we will have to see. I always measure twice before I cut and in this case will have to measure a lot before I even think about cutting. I would hate to have a third door that latches but isn't sealed and leaks. Or have a third door that is two thirds window!
The concept is simple, the conversion is not. Most concepts never see first stage production. Since I don't plan on marketing my project I will perfect the process then start it. This will be my first door add on. I have helped shave and get rid of doors on a friends chevy and that process was slightly easier then this.
If you already have an econoline you are half way there. You will need to cut the whole "3rd" side door section of the body and the "2nd" door's end that connects to the "3rd" door. You might have to section out the "3rd" door and it's frame to fit the F150, but all the hard work is done. I don't know how the glass will work, but you can cut out the glass section of the F and weld that in where the glass on the E door was. After this you would just need to reskin the door to get the body lines to match up. I'm not sure about the OEM hinges, but there are so many options out there you can find something that will work.
This reminds me of my old jobs motto.
"The only limitation is your imagination."
We always added "and you wallet." under our breath.
