Transmission Thermostats
Anyone with larger coolers think about using one of these? Seems like the larger coolers keep things too cool in the colder months.
http://97.74.103.94/files/thermos$.p...on+and+Pricing
I was around oil temperature regulators for years while I was flying. They were used in the engine oil cooing system. Air cooled aircraft engines use the engine oil for a suprisingly large amount of their total cooling.
The "Vernitherm" valve is a thermostat just like the one in your cooling system, except a little more precise. Most are adjustible (but you need a pretty complex setup to test them) and can bypass all of the oil past the cooler.
Many of the valves allow some oil to go through the cooler all the time, in order to keep it from getting TOO cold. Some oil coolers were designed to circulate oil through part of the cooler to keep it warm. They were calles "non-congealing" coolers, since the oil would otherwise get so cold it would act like diesel does at too low a temperature.
I clearly remember flying through a canyon in Canada at -35*F and looking down at the oil pressure gauge and seeing it dropping. It finally settled at the minimum operating pressure and I flew for another hour and a half to get to the nearest airport. The "non-congealing" oil cooler did not live up to it's name that day!
When living in Southwest Oklahoma my PI torque converter "ate itself" one day and sent a bunch of trash down range through the lines to the lower part of the radiator. During the repairs the lower radiator portion that the tranny fluid runs through was bypassed due to the obstruction. Didn't notice a problem in that climate.
During my first winter in South Dakota I would rarey see the trans temp gauge move and on occasion during real cold sub zero temps I would feel something that just didn't seem 100% right. Sent in a fluid sample to the lab and came back with elevated iron and high copper wear. After reading some of Mark K's posts and talking with BTS and J&M transmission we had the lower portion of the radiator cleaned and hooked back up.
In the past I was always in the hunt for lower tranny temps - not necessarily the best coarse of action in my situation now.
Thank you Mark K, BTS and J&M Transmission................
