Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-13-2010, 10:05 PM
Millenium Edition's Avatar
Millenium Edition Millenium Edition is offline
2000 Ford F-250
Millenium Edition is starting off with a positive reputation.
When EXACTLY did the 3 Valve 5.4L come out?
The '04 in my signature was built in January of 2004. I've heard a bunch of BS about whether it's a 2v or 3v. Owners manual says 3v, but I got called out on it earlier, so I wanted to start this thread to settle it once and for all. Any dead give-aways as to what engine it is? I'm really not trusting the owners guide right now.
__________________
2004 F-250 XLT, 5.4L, 4R100, 2WD, Ext. Cab, Longbed.
2000 F-250 XLT Millenium Edition, V-10, ZF-5, 2WD, Ext. Cab, Longbed. My Daily Driver.
1994 F-350 XLT, 7.3L IDI Factory Turbo Diesel, E4OD, 2WD Dually, Ext. Cab. (Dad's "Elanor")
1992 F-150 XLT Flare Side, 351W, E4OD, 4x4, Extended Cab. Work-In-Progress
1990 F-350 XLT Lariat, 7.3L Naturally Aspirated IDI, E4OD, 2WD Dually, Crew Cab.
  #2 (permalink)
Old 12-14-2010, 07:03 AM
phil6608's Avatar
phil6608 phil6608 is offline
Garage is empty, add now
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
When did it come out or when did they put it in a F250?
The F-150 got the 3V in 04. Not sure about the F-250
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
  #3 (permalink)
Old 12-14-2010, 07:35 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
2005 Ford F-250
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
'04 F250/F350 had the 2V. NONE of those got the 3V until '05, and the change was accompanied by the Torqshift trans. If you've ever driven a 3V, you'd immediately know the difference and not confuse it with it's 2V brother. They're night and day different.
JL
__________________
2005 F250 Crewcab 3V V10/Torqshift/4.10LS
2001 F150 Supercab 4.6L/4R70W/3.55
1997 Thunderbird LX 4.6L/4R70W 12.16@111.78
2010 Lincoln MKT Elite-3.5L EcoBoost/AWD 14.41@96.27
  #4 (permalink)
Old 12-14-2010, 09:47 AM
2000 Ford F-250
Was variable cam timing only a 3v thing, or did 2v's get the same treatment at some point?
__________________
  #5 (permalink)
Old 12-14-2010, 10:09 AM
2005 Ford F-250
2V's 4.6L's, 5.4L's, and 6.8L's never had VCT. None of them. The 3V 6.8L also does not have VCT.
JL
__________________
  #6 (permalink)
Old 12-14-2010, 11:12 AM
2000 Ford F-250
Alrighty. Thanks for the help Johnny, and Phil. I appreciate the advice.
__________________
  #7 (permalink)
Old 12-14-2010, 10:53 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1 EXCURSIONATOR1 is offline
EXCURSIONATOR1 is gaining momentum as a positive member of FTE.
Ok this is a good thread!
If the 3v 6.8 v10 didn't come with a vct can it easily be swappped for a 5.4 2v? Or a 6.8 2v?
Someday soon the 5.4 is coming out of my excursion either a 2v v10 is going in or something better.Me personally donot like the 2v v10. But a 3v now thats sounds like something I might be alittle more interested in
  #8 (permalink)
Old 12-15-2010, 07:00 AM
2005 Ford F-250
The Cam Position Sensor is on the opposite bank on the 3V 6.8L vs the 2V 6.8L.
I have not looked into whether the cam gears could be swapped that would allow you to use the 2V's Cam gear and CPS on the 3V, so I do not know if that's a feasible idea or not.
I honestly prefer the 3V myself, but IMO-swapping in a torqshift would be a much more useful and effective. I've been looking into the possibility of using an '05 E-Series PCM in our Excursion and swapping in a torqshift.
JL
__________________
  #9 (permalink)
Old 12-15-2010, 08:46 AM
Couldn't extending the cam positioning harness work?
Sorry for the thread jack.
  #10 (permalink)
Old 12-15-2010, 08:50 AM
2005 Ford F-250
It's not that simple. The CPS reports the position of the camshaft in relation to bank 1 on a 3V, and bank 2 on a 2V.
JL
__________________
  #11 (permalink)
Old 12-15-2010, 09:45 AM
2000 Ford F-250
. . . Sorry for the thread jack.
Don't worry about it. I'm learning stuff from this as well, so carry on
__________________
  #12 (permalink)
Old 01-27-2011, 08:03 PM
REXHOUND REXHOUND is offline
REXHOUND is starting off with a positive reputation.
2005,and btw thay are turds with there stuck plug problems,just sayin
  #13 (permalink)
Old 02-07-2011, 09:32 AM
2000 Ford F-250
Quote:
You're referring to the 3v engines, correct?
__________________
Tags
10, 3v, 54, 54l, 5r110, 68, excursion, f250, ford, installing, out, pickup, put, v10, valve, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
