Motorcraft carburetor vacuum connections? - Ford Truck Enthusiasts Forums
Old 12-13-2010, 11:02 PM
Heather_M Heather_M is offline
Heather_M is starting off with a positive reputation.
I recently installed a new Motorcraft 2 barrel carburetor on my 1972 Ford F-250. It is automatic, with the 360 engine.
The old carb had a manual choke, the new one (I'm guessing?) is electric, as it has no linkage for the choke cable.
I've never done a carb before, so this is all new for me. I put the new one on exactly the way the old one was. There are a few things I suspect weren't correct on the old one, though...it had only one small vacuum hose, running from the distributor to a connection on the passenger side of the carb, below the choke.
I see a place on the new choke that looks like it should have a hose connected to it, and there are two connections on the back of the carb, that seem to be for hoses but nothing was hooked up to any of them on the old carb.
This picture shows a loose vacuum hose that is plugged with a screw, I'm wondering if this is supposed to hook somewhere to the carb or the choke?
The truck starts up fine, but once the engine warms up, it will repeatedly die at idle--once it cools down, good again for a little while, then same thing, just won't stay running unless I have the pedal almost to the floor. So I've obviously got something on it wrong or disconnected.
I did not turn any of the 3 adjustment screws, I put it on the way it came out of the box.
Here are a few pictures of the old carb, and the new one, not the best pics but might help. I can get better pictures tomorrow if you need to see something specific, just let me know what to photograph.
Thanks!
Old 12-14-2010, 06:12 PM
Able Dog Able Dog is offline
Able Dog is starting off with a positive reputation.
That round plastic cover on the side of the carb is the choke and if memory serves me right, it was set on two rich. From your pics it looks like the previous owner disabled it and added a manual choke.
Try hooking that loose vacuum line to the line on the side of the carb near the choke.
As for the two ports in the back of the new carb, I only remember one and it was blocked off with a rubber cap.
Good luck.
Need a little help MI79250 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-13-2011 09:39 PM
my 2011 f350 with new western wide out snowplow fatheadon1 6.7L Power Stroke Diesel 19 10-03-2011 04:26 PM
Destroked 12vexcursion Excursion - King of SUVs 19 07-10-2009 06:14 PM
got my wheels and new tires on 42nineranger 1999 to 2016 Super Duty 72 03-30-2009 05:13 PM
put a 7" tip on my truck 42nineranger 1999 to 2016 Super Duty 20 02-25-2009 06:30 PM
Tags
1979, 83, carburetor, carbvacuum, choke, f150, ford, hook, hoses, instruction, manual, motorcraft, national, tubing, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
