'51 F1, Engine is stalling
Had this problem w/ my 56. It ocured whenever I filled up the gas tank. The gas filter would plug w/ rust. Looking into my tank with flashlite, it looked spotless. apparently PO always kept tank 1/2 full. Got a drop lite and dentist mirrror and found the top half of the tank was full of crud.I removed and acid washed the tank, then applied a sealer. I filled the tank and haven't had any more plugging problems. So I'm hoping that at least that problem is fixed
Humpl
Humpl
Just to be clear, over a 50+ yr period you get more than a little bit of crap... this came out of my glass fuel bowl on the fuel pump, after I started rapping on the fuel lines from the tank. I got 3X as much out of the fuel lines, but only by beating on them with a hammer, off the truck. At which point I ran down to NAPA and bought new internally coated lines.
The thing above your carb is the oil bath air filter.
Gas tank comes out easily - there are only 2 bolts inside the tool tray that thread into caged nuts. Remove the fuel line on the bottom of the tank. That's it. Lift up and out.
The tank should have a shutoff valve on the bottom of the tank. Leave it on the tank.
For what it's worth, I had a similar problem with my 50 last year. Seemed to be fuel. The truck would idle and then breakdown while driving. Eventually, it stopped altogether. After much searching, the problem was a bad connection at the ignition switch. It was smooth enough at idle to be OK but moved when driving. As the connection moved, the engine broke down because there was not enough juice going to the ignition but it sure acted like a fuel problem. If you don't have luck with the fuel filter, check the voltage and amperage at the coil and the distributor before pulling the tank just to be sure that your problem is not ignition rather than fuel. (It's a lot easier to check voltage and amperage that than to remove the tank).
When getting my truck on the road I had the tank out so often it was like working on a pit crew. Think my record was 10 minutes to remove the tank and turn it upside down over a 5 gal bucket to empty it.
A piece of clear plastic label was the cause - couldn't see it in the tank and almost invisible in a bucket of gas. It took a few times to find it.
Hi Everyone-
I am happy to tell you that after flushing the Tank, replacing the Coil, replacing the fuel lines, plugs, distributor, conversion from 6V to 12V and most importantly, REPLACING the FUEL PUMP, my stalling problems have been resolved. Julies Cool thanks for the suggestion. It has been a fun process getting to know my Engine!
#28
Thank you to everyone for your suggestions. I have just purchased a restored 1951 Ford F1 and it is having the exact stalling issues as described by everyone. Your suggestions are great. I replaced the carburetor with a new one - same problem. I'm leaning toward the tank, the lines, and the coil. Great information. Thanks.
3twinridges
05-25-2016 03:49 PM
