1978 - 1996 Big Bronco
Factory replacement Vacuum lines
Old 12-13-2010, 08:43 PM
v8xploder's Avatar
v8xploder
v8xploder is offline
Working on the 92 yesterday and I broke 2 colored plastic vacuum lines. Who makes a replacement or i guess i could get some rubber vacuum line at auto parts store but id rather keep things clean and factory. Ive searched, anyone have a lead on where I can get replacements.?? Ford doesnt sell them anymore.
Old 12-13-2010, 09:03 PM
igotoneforya's Avatar
igotoneforya
igotoneforya is offline
funny, i broke one yesterday and one today, but only the ends so i just stabbed the new broken ends into the rubber coupling or attachment point...all better...and one hose clamp
Old 12-13-2010, 09:19 PM
FourXFord2's Avatar
FourXFord2
FourXFord2 is offline
i have used colored heat shrink tubing from Radio Shack before, use at least 2 inches less pulled out for me.
Old 12-13-2010, 09:55 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
The hard plastic lines are not readily available aftermarket. Replacement should be done with something that will withstand the temperature and elemental abuses they are subject to. Many have had good luck with neoprene and vinyl tubing from McMaster-Carr and other such suppliers.
Old 12-13-2010, 11:19 PM
monkei's Avatar
monkei
monkei is offline
is nylon okay for use with gasoline vapors???
Old 12-14-2010, 07:17 AM
maxbodyworks's Avatar
maxbodyworks
maxbodyworks is offline
Hey,...guess what ,...?,...I have had the same problems,..i just grabbed some silicone tubing, and used it to "couple" the broken,...plastic crap that was original. For a cleaner, more functional alternative, I have some copper pipe from the hardware store,..the thin flex type,... problem is if its not the correct diameter is it going to provide the resistance to run the smog crap on the other end. And there are three of them I think that come around the back of the upper intake,..so some type of bracket will have to be fabricated, as well as connection from the pipe to the device,...(egr, coffee can, or what ever). Not sure on nylon for gas vapors,...I wouldn't for liquid gas so I wouldn't for vapor,.... it will just get brittle and break. Good luck with the pipes,....
Old 01-17-2011, 04:07 AM
Capone's Avatar
Capone
Capone is offline
I used reinforced nylon from mcmaster carr. I believe that 5/32in is the correct diameter.
Old 01-17-2011, 05:53 AM
b4hntn's Avatar
b4hntn
b4hntn is offline
I replaced all the plastic vacuum lines under the hood except the MAP with almost 25 feet of 5/32 rubber. I heated the ends in hot water to slip over the intake manifold tree. I was not aware of leaks but the engine runs better. I took a picture of the hood sticker and printed it. Noted which solenoid position and described the controlled part location. I numbered the hose colors and put the corresponding number on the hoses with wire number tags. Picture is kept in the console now in case ever needed.
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
Long-shot
1999 to 2016 Super Duty
07-15-2017 02:35 PM
LeviD
06-01-2017 10:20 PM
Ford77Pickup
03-02-2017 09:06 AM
mmenzies
11-07-2012 12:02 AM
Quick Reply: Factory replacement Vacuum lines
