1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
esof nv273 transfer case swap to nv271, help please (some pictures inside)
Old 12-13-2010, 08:17 PM
f250-ksa's Avatar
f250-ksa
f250-ksa is offline
good moring every body
im not new to this forum but im not writing too much
i used to search in this thread always when i get stock with my truck
i had some problems, (alhamdo lellah) i fixed it
my transmission (zf s-47) was serviced 2 months ago, after the installation i figured that the tranfer case duesnt work (nv273).
i checked the dtc devise and it showed that the transfer case motor is damaged, bought a new one recently (240$)
the problem is the motor didnt work !!
in fact the main problem was from the connector
some times when i push it strongly the high range works, but low range duesnt !
after a while when driving by the truck it returns to failure, need more push
here is the new motor
even after putting some holders on the connector the low range dodnt work
some wire where cutted so i fixed it as you see in the right area of pic
after alllll these problems i decided to swap the electronic motor by manual sticks
06silvercrew
did it, i sent a massege but he didnt answer me
ESOF to manual conversion
im pretty sure it is suitable, but inneeded some help
i know my language is too bad but at least im learning
my sweet truck
some links i searched in but didnt help
https://www.ford-trucks.com/forums/6...l-or-esof.html
https://www.ford-trucks.com/forums/1...to-manual.html
best wishes
zakariyya
Old 12-14-2010, 09:50 PM
f250-ksa's Avatar
f250-ksa
f250-ksa is offline
1 full day without any replies ??
Old 12-15-2010, 05:37 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Where are you located?
Old 12-15-2010, 09:18 AM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
It sounds like you just have electrical connection problems.
Old 12-15-2010, 05:39 PM
f250-ksa's Avatar
f250-ksa
f250-ksa is offline
faraway, in ksa (saudi arebia)
the country of gmc's, a lot of them and few sd's
aha
i checked the wire it self as long as it is (the motor wire)
there aren't any strange things, i forgot to say: the fuse box isn't working
i mean they dont link or flow the electricity. checked whith speical tool.
Old 12-15-2010, 06:15 PM
f250-ksa's Avatar
f250-ksa
f250-ksa is offline
here is a very good link
it is exactly what i am looking for
https://www.ford-trucks.com/forums/8...ion-build.html
GCally
01-23-2019 09:50 AM
A/Ox4
Projects
45
04-15-2013 03:45 AM
F250army45d
06-27-2010 05:40 PM
Greywolf
General Automotive Discussion
163
07-01-2009 09:15 PM
rockher_man
13
03-01-2009 01:41 PM
Quick Reply: esof nv273 transfer case swap to nv271, help please (some pictures inside)
