EFI ?
220 HP -eeeh! mid size truck engine... what can fit aero? OM904LA, Cummins B-series ore ISL, Cat 3126.... anyway heavy engines.. a lot of welding and cutting work + truck transmission, may be alisson auto, may be ZF ore Eaton.
I think Brothers Performance (BBK) may still have a small supercharger for the 4.0 liter v6. It will actually generate the power levels you want, without blowing the head gaskets. But it was designed for trucks like the Ranger or Explorer, so it is a little too tall for the Aerostar. However, I've seen the modifications you've done before, so I'm pretty confident that you can figure something out.
The 4.0L won't take it. You need forged internals and lower compression. The engine will run ok on boost for a little while, but as soon as something goes wrong, the engine will self destruct.
For what you are trying to do, the cost or value of the van is irrelevant. Either you want a high powered Aerostar or you don't. People will shell out $10,000 to put out 300 whp in a 1990 Civic. When you are doing this kind of work where you may have to cut and paste, a cheaper vehicle is almost ideal, especially if it is your first time doing something like this.
If you really want to put out some power, go for a 2.3L Turbo motor out of a late eighties Mustang, Thunderbird, or Merkur. The stock motor is just 164 hp, but it is smaller and lighter than a V6. Thew stock motor can handle up to 400 hp before the internals have to be further upgraded. The great news is relative to a performance versus cost, these engines are fairly inexpensive.
#28
HP and torque are really equivalent. Horsepower is really nothing more than a dynamic measurement of torque. Torque is commonly referred to as a low end power figure, but in reality, horsepower is a measurement of power versus time. You can have a vehicle that produces a lot of power at low RPM, yet doesn't produce much horsepower. Such a vehicle can be almost unstoppable, and slow as a turtle because it still doesn't produce any real power.
If you set up the 2.3L with a turbo that spools quickly and produces good boost at low RPM, it will produce way more torque than a naturally aspirated 4.0L, or even a naturally aspirated 5.0L. It doesn't matter that the Aerostar is heavy at that point, power is power when geared correctly.
#29
For the application, torque is required.
Torque is a measurement of force. Horsepower is how fast the work gets done. A tractor and a motorcycle can both have 100 hp. The difference is how fast the work gets done.
How well would your Aerostar get moving if you had to wait for the turbo 2.3 to spool up, then shift pretty often to keep it in its power range? The 4.0 has torque down low, and isn't working as hard to make what power it does. A V8 would be even better, more torque and less stress on the engine.
I have a '99 Sable with the 200 hp engine. I also have a '96 Windstar with a 200 hp engine, but more torque. If I got the weights pretty similar (load down the Sable), the Windstar would be quicker off the line. On the Sable, you have to wait till about 3500 rpm for it to get into the power band, and then it takes off.
More extreme is the 300 straight six in my dad's F150. It can chirp the tires off the line, but runs out of steam at 55-60 mph.
With a stick shift you cant down shift so you need speed at the bottom without stalling at the top.
