P0309 Help - Ford Truck Enthusiasts Forums
P0309 Help
Old 12-13-2010, 06:38 PM
901fan 901fan is offline
901fan is starting off with a positive reputation.
P0309 Help
Hey guys,
I have searched and actually have fixed a few things in advance of posted this request so thanks.
We have a 99 F250 V10 that for a while ran perfectly.
About a month ago it started bucking under load. It threw a P0300 Code.
So I bought some C.O.P's from ebay and installed all 10. Drove it for about a week and again same thing. This time it threw P0300 and then a couple of days later it threw P0309 again. So I bought a FORD C.O.P and a new Motorcraft plug and swapped them out only on Cylinder 9. Again it drove like a champ for about 150 miles then back to bucking, same thing P0300 then P0309.
Within the last month I have swapped these parts as preventative mantainence.
MAF,TPS,Fuel Filter.
I need to check the fuel pressure but at this point I think it is related to fuel as if the tank is full it is not as likely to act up and the last time it acted up it was right as the tank got low.
What should I check next? I ordered a New fuel Inj for that cylinder.
Any thoughts on quick fixes?I have not checked for vacuum leaks.
Old 12-14-2010, 06:53 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
If you keep getting a #9 misfire (0309), it could be an injector on cylinder #9 based on what parts you've changed. The injector isn't spraying right, it fouls the plug and it starts to misfire. When you pulled the plug, what did it look like?
You might also want to do a compression check and compare the other cylinders to #9.
Sometimes, from reading here, a single injector seems to be able to cause a random misfire, because it will screw up other cylinders at the same time.
Old 12-14-2010, 08:01 AM
Thanks for the reply. The plug was black at the base, I will have to grab it again and see exactly what it looks like. I am hoping for it to be the injector. It has not burned oil or done anything odd until now so I am hoping it is not something internal.And the fact that it comes and goes, sometimes if you hammer it it will clear up and run fine for a while. I would think if it had some compression problems it would act up constantly.
Old 12-14-2010, 05:23 PM
68 351 bronc 68 351 bronc is offline
68 351 bronc is starting off with a positive reputation.
I read one time about a guy that had a similar problem. His O2 sensor was bad and caused the engine to run rich and foul plugs. I'm not saying change the O2 sensor, just might want to check the Ohms.
2001 6.8 v10 got wet n now misfiring 01f250v104x4 1999 to 2016 Super Duty 3 02-05-2017 04:24 PM
2003 Ex V10 Extremely Rough Idle BigBair Modular V10 (6.8l) 44 10-25-2016 09:08 PM
1999 F-250 V10 6.8 p0300 and p0401 codes dyrtyv10 1999 to 2016 Super Duty 10 06-04-2015 07:58 AM
F250 5.4 Multiple misfires Roddy's Dad 1999 to 2016 Super Duty 10 01-09-2015 07:37 AM
Help diagnosing a 2006 F250 5.4L Triton Piratejonh 1999 to 2016 Super Duty 9 10-21-2012 09:07 PM
Tags
0309, 2000, 2009, 68, 98, code, cylinder, engine, error, escape, expedition, f250, ford, misfire, p0309, taurus, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
