97 F350 o2 sensor - Page 2 - Ford Truck Enthusiasts Forums
97 F350 o2 sensor
Old 12-15-2010, 08:45 AM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Quote:
Originally Posted by rla2005 View Post
Thanks Dan for helping out. The O2 sensor wiring is tied together with the MLPS and solenoid pack wiring. Remove that heat shield to gain access to the solenoid pack connector. Then remove the connector from the MLPS. Now that cable bundle can be pulled down from around the transmission for a visual inspection.
Your welcome and yea, the all important solenoid pack, I see I left that out of my short list!
Quote:
Originally Posted by 66ca View Post
What is MLPS?
Manual lever position sensor, on the side of the trans where the shift linkage connects, tells the computer what the driver selects.
Old 12-15-2010, 08:57 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Manual Lever Position Sensor. It is a sensor on the driver side of the transmission. That is what tells the PCM what "gear" the transmission selector is in.
Old 03-13-2014, 12:51 PM
bpgraham bpgraham is offline
bpgraham is starting off with a positive reputation.
Do you know which wires hook together on the O2 Sensor? I have a 96 F350 with the 5.8l and the wires were ripped off at the plug. I have 4 wires coming from the Sensor. A black and 2 white and another wire that I'm cleaning to figure out the color. The wires where the plug was are Orange, Gray/light Blue, Black, Purple/Orange. Any help will be appreciated!!
Old 03-13-2014, 03:49 PM
rla2005's Avatar
If the fourth wire is gray then you may find this helpful:
All Bosch 4-wire sensors have a black wire for the signal, a gray wire for ground and 2 white wires for the heater.
Reference this diagram for the functions of each wire at the connector:
Old 03-13-2014, 04:08 PM
So, make sure I have this correct... the Orange and Gray/Light Blue wires go to the heater (White) wires. Black in the harness to Gray on sensor and Purple/Orange wire in the harness to Black on the Sensor.......
Old 03-13-2014, 05:13 PM
rla2005's Avatar
Orange= O2 Signal = Black wire on O2 sensor
Gray/Light Blue= O2 Signal Return/Ground = Gray wire on O2 sensor
Purple/Orange= O2 Heater supply Voltage = White wire on O2 sensor
Black= O2 Heater Ground = White wire on O2 sensor
O2 heater circuits gone bad? ojh Explorer, Sport Trac, Mountaineer & Aviator 28 08-03-2016 02:51 PM
Hooking Up A Stock Ford Air Cleaner LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 06-26-2016 07:25 AM
Injector Control Pressure Sensor Mod DDPJ 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-04-2014 06:51 AM
Scan tool reads bank 2 fuel sys. N/a? Mass928 Modular V8 (4.6L, 5.4L) 18 07-11-2014 08:19 AM
bap sensor question ihf-350 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 12-19-2011 04:52 PM
Tags
02, 1994, 1997, 58, 97, digagram, f350, ford, lever, location, manual, mpls, o2, picture, position, sensor, sensors, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
