Radio Wiring Diagram
Old 12-13-2010, 02:02 PM
88 250's Avatar
88 250
88 250 is offline
Question Radio Wiring Diagram
Does anyone have a picture of the radio wiring diagram for an 88 250? If you have the diagram for the light dimmer switch that'd be awesome too! Thanks ahead of time!
Old 12-13-2010, 03:48 PM
subford's Avatar
subford
subford is offline
Radio:
Radio Illumination:
Dimmer switch:
Old 12-13-2010, 03:49 PM
nstueve's Avatar
nstueve
nstueve is offline
x2 above subford beat me...
Old 12-13-2010, 04:28 PM
88 250's Avatar
88 250
88 250 is offline
Thanks. My dash lights weren't working so I pulled my radio out to see of there were any wires hooked up wrong. The previous owner had the ground hooked up to the LB/R wire which was the illumination wire. Hooked my ground up to the correct wire and problem fixed!
Old 12-13-2010, 06:21 PM
IDI Diesel's Avatar
IDI Diesel
IDI Diesel is offline
related to the radio...has anybody swapped in a new radio with a cd player or the sort? Iv been looking into it but how in the world does the antenna disconnect at the back of the radio? I have a 1991 F250
Old 12-13-2010, 06:55 PM
subford's Avatar
subford
subford is offline
It pulls out.
Old 12-13-2010, 11:07 PM
88 250's Avatar
88 250
88 250 is offline
I put in an Alpine CDE-100 and love it. And the antenna just pulls out.
Old 12-13-2010, 11:19 PM
illini5190's Avatar
illini5190
illini5190 is offline
I just found out that the "illumination wire" in the adapter harness for our trucks is not actually attached to the dimmer switch for the interior lights. The only way to actually get your head unit to dim with your interior lights would be to run a wire directly from your dimmer switch to the illumination wire on the head unit. Otherwise you are better off just capping off the wire because it does nothing. This is according to tech support from crutchfield.com
Old 12-14-2010, 07:26 AM
subford's Avatar
subford
subford is offline
This is on a 2002 Ford?
Old 12-14-2010, 10:13 AM
illini5190's Avatar
illini5190
That is correct. Like I said that is at least what the people from Crutchfield told me. I haven't actually traced out the wire on the wiring diagram itself to confirm it.
Old 12-14-2010, 10:39 AM
subford's Avatar
subford
subford is offline
Not true, here is the 2002 wiring diagram, radio is at the bottom right.:
Old 12-14-2010, 10:43 AM
illini5190's Avatar
illini5190
Well what the heck those people lied. Now I'm going to have to tear my head unit back out and connect up that wire. Thanks for setting me straight. They sounded like they knew what they were talking about but obviously didn't.
Old 12-14-2010, 11:40 AM
subford's Avatar
subford
subford is offline
Here is a blowup of the radio area.
It would be the radio pin#1.
77Hulk
09-23-2016 04:25 PM
finitetime
1997 - 2003 F150
11-22-2014 04:09 PM
cpetersen
01-13-2011 06:55 PM
F250Wheels
07-25-2005 12:13 PM
bozzchem
07-02-2001 12:31 AM
Quick Reply: Radio Wiring Diagram
