Radio Wiring Diagram - Ford Truck Enthusiasts Forums
Old 12-13-2010, 03:02 PM
88 250's Avatar
88 250 88 250 is offline
88 250 is starting off with a positive reputation.
Question Radio Wiring Diagram
Does anyone have a picture of the radio wiring diagram for an 88 250? If you have the diagram for the light dimmer switch that'd be awesome too! Thanks ahead of time!
Old 12-13-2010, 04:48 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Radio:
Radio Illumination:
Dimmer switch:
Old 12-13-2010, 04:49 PM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
x2 above subford beat me...
Old 12-13-2010, 05:28 PM
88 250's Avatar
Thanks. My dash lights weren't working so I pulled my radio out to see of there were any wires hooked up wrong. The previous owner had the ground hooked up to the LB/R wire which was the illumination wire. Hooked my ground up to the correct wire and problem fixed!
Old 12-13-2010, 07:21 PM
IDI Diesel IDI Diesel is offline
IDI Diesel is gaining momentum as a positive member of FTE.IDI Diesel is gaining momentum as a positive member of FTE.
related to the radio...has anybody swapped in a new radio with a cd player or the sort? Iv been looking into it but how in the world does the antenna disconnect at the back of the radio? I have a 1991 F250
Old 12-13-2010, 07:55 PM
subford's Avatar
It pulls out.
Old 12-14-2010, 12:07 AM
88 250's Avatar
I put in an Alpine CDE-100 and love it. And the antenna just pulls out.
Old 12-14-2010, 12:19 AM
illini5190 illini5190 is offline
illini5190 is starting off with a positive reputation.
I just found out that the "illumination wire" in the adapter harness for our trucks is not actually attached to the dimmer switch for the interior lights. The only way to actually get your head unit to dim with your interior lights would be to run a wire directly from your dimmer switch to the illumination wire on the head unit. Otherwise you are better off just capping off the wire because it does nothing. This is according to tech support from crutchfield.com
Old 12-14-2010, 08:26 AM
subford's Avatar
Quote:
This is on a 2002 Ford?
Old 12-14-2010, 11:13 AM
That is correct. Like I said that is at least what the people from Crutchfield told me. I haven't actually traced out the wire on the wiring diagram itself to confirm it.
Old 12-14-2010, 11:39 AM
subford's Avatar
Not true, here is the 2002 wiring diagram, radio is at the bottom right.:
Old 12-14-2010, 11:43 AM
Well what the heck those people lied. Now I'm going to have to tear my head unit back out and connect up that wire. Thanks for setting me straight. They sounded like they knew what they were talking about but obviously didn't.
Old 12-14-2010, 12:40 PM
subford's Avatar
Here is a blowup of the radio area.
It would be the radio pin#1.
87 radio wiring diagram cpetersen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 01-13-2011 07:55 PM
94 f150 radio wiring diagram chrismartinez0 1987 - 1996 F150 & Larger F-Series Trucks 2 06-27-2010 08:38 PM
radio wiring '88 F-150 mreggball Electrical Systems/Wiring 1 11-30-2006 07:08 PM
2006 F250 wiring diagram SAMboTEX 1999 to 2016 Super Duty 2 10-22-2006 03:11 PM
radio wiring diagram for a 99 ford ranger F250Wheels Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 07-25-2005 01:13 PM
Tags
1988, 1996, 2002, 250, 350, 88, coachmen, diagram, f150, f250, f53, ford, radio, stereo, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
