new tires?
new tires?
Im new to the diesel truck game. (and this forum which Im glad to have stumbled upon.)
I just purchased a 1991 f-250 w/a 7.3 diesel. It has a set of 235-80-16's on her.
My question is how big of a tire can fit without lifting the truck, damaging the drivetrain, or rubbing of course?
265's, 275's, 285's, 33x12.50's, 35x12.50's or bigger maybe?
I just want the truck to look a little meaner. Thanks in advance and again glad to be part of the community.
Thanks for the feed back guys. I had no idea something that big would fit.
It is a 4x4 and I will do a little off roading from time to time. nothing like some of the guys I've seen on this forum, but I will get her dirty.
I will mainly use it as a winter truck and to tow my classic cars with when needed.
if i remember correctly increasing the diameter of the tire will increase my gear ratio slightly. So just for an example (not correct #'s or math) if I put a tire on that is 3" taller than the stock tire and the truck has a 4.10 gear ratio the taller tire will change the gearing to say a 3.90?
Does anyone know of a website that would allow me to type in tire sizes and give me these gearing specs?
- Dirt Road Magazine - Gear Ratio Calculator - (dirtroad.com)
Theres some calculators there. The 1st calculator is the one you want, and then you use this formula
A - B = C
B - C = D
A = New gear ratio from calculator, B = Current gear ratio, C = Computed difference in ratio, D = Equivalent gear ratio
Using your current gears/tires (31's & 4.10) if you went to a 35, you would need a 4.63 gear to stay at stock rpms. Take the 4.63 (A) subtract 4.10 (B) and you get .53 (C)
Now take the 4.10(B) and subtract the .53(C) and you get 3.57(D) which would be your equivalent gear ratio with the 35" tires on stock gears.
A - B = C
B - C = D
thanks for all the help L.Ward, may the 4x4 gods smile upon you! By the way love your avatar!
Im thinking I may go with the 285/75-16's they will through the speedo off by 3.9 mph and give me a drive ratio of 3.78. Theirs better sizes that wont change things up so much but the other sizes dont seem to come in load range E's.
If I do go with the 285's they wont damage the drivetrain or 4 wheel drive system right?
