1992 F-150 misses and cuts out, sputters.
I have a 1993 F-150 with a 5.0. About a week ago it started missing and sputtering under a load. If you just ease the gas its kinda ok but if your trying to go up a hill in overdrive it cuts in and out. Sputters. Like it has a miss. I installed new plugs, wires, cap n rotor but no luck. I thought it was something with spark but none of these helped. What the hell is it? Injectors? Coil? Help!
Does it smell rich? Do you have cracks in your exhaust manifold? Do your inatke manifolds leak? Is your idle low, normal, or high? If no to the first three questions then tps (it is like 20-30$ at autozone) I'm trying to keep it cheap on you my 90 f150 it used to sputter like absolute dog hell and would die randomly I swapped the tps I still had it under warranty at autozone and has ran no sputter or stalling. Unless your idle is retardedly low I highly dought it is your IACV. Your coil I dought that cause 9/10 times that just dies or you have so much of an spark delay it won't run correct if it does start. Injectors ehh unless something managed to get them dirty in a weeks time with no signs leading up to its current condition I find that unlikely, did you do the fuel filter? Other than possibly the fuel filter or TPS I am just about out of thoughts
I am having the same problems. My speedo went haywire and ABS light came on the same time. I found this web site apparently the 60 pin connector by the fire wall can cause this.
http://ww2.justanswer.com/uploads/ba...ion_module.pdf
Bradcook21
04-10-2017 07:08 PM
Anthony Hyde
07-16-2016 12:11 PM
87 Ford F-150
03-16-2016 09:03 PM
geoasis
20
03-26-2015 02:46 PM
