p0012 i have already replaced vct solenoid - Ford Truck Enthusiasts Forums
Old 12-12-2010, 03:40 PM
mario_04f150 mario_04f150 is offline
mario_04f150 is starting off with a positive reputation.
Im having problems with the VCt solenoid, the engine light came on and had autozone run the code and came up with p0012. so i replaced the vct passenger side solenoid, and light was off for about an hour and then came back on, i went to have the codes checked again, and it gave me the same code. is their another sensor that could make this code come on? it does idle a little bad. any info
i called the ford service department and they the vct solenoid has to be programed into the PCM, is that true? is their a way to do it without having to take it to the, they want to charge me 220 to do it..
Old 12-12-2010, 06:48 PM
bjl95mustang bjl95mustang is offline
bjl95mustang is starting off with a positive reputation.
My truck had a rough idle and the same code. It ended up having bad cam phaser,chain tensnors, and guides. Mine was so bad it skipped a tooth and had cut 1/2" into the front cover.
The light will take 2 cycles before it comes back on after it's reset.
Old 12-12-2010, 06:59 PM
well the idle isnt too bad yet, i just notice the rpm needle drop a little..
Old 12-14-2010, 12:10 AM
I have been researching the vct and I have never heard about the vct needing to be programmed.
Mine drove fine until a few weeks ago. Then one day I noticed the cel was on. I got code p0012. The engine still ran fine but my mpg dropped to 12 and had very light miss at idle.
I had the phazer knock so I took it in. After they tore it down they found a bad right side phazer, and all of the chain tensnors and guides were shot, and the timing chain skipped a tooth.
After seeing all of the damage I was surprised on how well the truck ran with the bad parts and the timing being off. I got lucky and my extended warranty paid for pretty much all of it. If not I would have been out $1400 for the repairs.
VCT replacement help contento EcoBoost (all engine sizes) 1 07-07-2016 02:05 PM
The good old p0012 code 1988ttop 2004 - 2008 F150 1 06-30-2015 08:30 PM
Questions about VCT System - P0012 and P0021 Codes jtillery 1997-2006 Expedition & Navigator 6 02-15-2014 02:49 PM
2005 Expedition code P0012 pholahan 1997-2006 Expedition & Navigator 6 03-06-2011 05:50 AM
5.4 3v VCT solenoid/phaser question: tomclem 2004 - 2008 F150 16 01-20-2011 11:11 PM
Tags
0012, 04, 2004, 2008, 54, code, engine, f150, ford, p0012, problems, solenoid, truck, vct, vmanage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
