Four wheel drive not working at all !!! - Ford Truck Enthusiasts Forums
Old 12-12-2010, 02:10 AM
1979BEAST's Avatar
1979BEAST 1979BEAST is offline
1979BEAST is starting off with a positive reputation.
Cool Four wheel drive not working at all !!!
Hey guys got a real bad snow/ice storm today and got stuck in a 2ft drift and found out my 4x4 is not working !!! Need help expose to get 15in this weekend
The truck has manual trans, manual transfer case, and manual hubs I've never had a problem with this before with a full manual system with electronic systems I've had problems blowing fuses and that's why I went with manual
Need help bad can't even pull in my drive way with out getting stuck !!!
Thanks guys
Jordan
Old 12-12-2010, 02:31 AM
Muktown's Avatar
Muktown Muktown is offline
Muktown is gaining momentum as a positive member of FTE.Muktown is gaining momentum as a positive member of FTE.
I would check out the hubs first. It only takes one of them not grabbing to make 4wd not work since its an open diff on the front
Old 12-12-2010, 02:47 AM
1979BEAST's Avatar
How do I go about doing that ?
Thanks for the quick response
Old 12-12-2010, 03:02 AM
Muktown's Avatar
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Im assuming the auto ones and manual ones come apart the same or at least similar
Old 12-12-2010, 03:09 AM
Muktown's Avatar
Jack the front of the truck up in 2wd lock the hubs and if you spin one front tire the other shuld spin the opposite direction. If the other side doesn't spin then its a locking hub issue
On edit never mind an easier way is to crawl under the truck grab the front driveshaft you should be able to spin it in two wheel drive then go out lock the hubs and you shouldn't be able to turn it. If you can its a hub issue. If you can't then unlock the hubs put the truck in 4wd you shouldn't be able to turn the driveshaft. If you can its a transfer case issue.
Old 12-12-2010, 04:05 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
if you have aftermarket hubs like warn hubs they can come apart. Mine have been doing it, I haven't torn it apart yet, but pretty sure the cause is the needle bearing inside the sealed bearing unit that the axle shaft rides in. Yes you can replace that one.
Old 12-12-2010, 04:15 AM
1979BEAST's Avatar
Okay ill try that and wut do I do if its a hub problem ? How much do warn hubs cost for these truck or are there better hubs spicer maybe or dana or other companies that make good hubs ? I don't like the ones that are on it they don't specify locked or unlocked
Old 12-12-2010, 07:12 AM
firemaster's Avatar
firemaster firemaster is offline
firemaster is gaining momentum as a positive member of FTE.
Warns are pretty much what everyone here uses. Look here
Riffraff Diesel: Warn Hubs
Old 12-12-2010, 02:15 PM
Bonanza35 Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
If somebody just did brakes on this and took the hubs apart since the last time you used them they mit not put it back togther right. It happen to me off road in wyomig on a hunting trip and couldn't make it up the hill. Went back to town took it apart reinstalled it the right way and off I went, worked perfect. Just a thought.
Old 12-12-2010, 07:04 PM
1979BEAST's Avatar
Okay tried this lock hubs canrt turn drive shaft unlock and put t-case in 4x4 can't turn drive shaft so why wouldn't my front tires spin last night when I needed my 4x4 ?
Unlock everything drive shaft spins freely
Thanks
Old 12-12-2010, 07:19 PM
here any noises when it wasn't turning your tires?
I have seen splines on driveshafts be bad enough that under power they would slip but you couldn't spin them by hand for example.
Also are you SURE your tires weren't spinning? Or just not the one on the drivers side.
Old 12-12-2010, 09:10 PM
1979BEAST's Avatar
No noise and I could feel the transfercase engage but when the GF and her sister hoped out to see if they were spinning and they wernt just the back tires and the speedo sed I was going 15mph and just the back tires were spinning
The 4x4 worked last week when I used it and about a month ago when I used the truck to put a new deer stand up I got stuck in sand kicked on the 4x4 and pulled out of my ruts
I don't understand why they wouldn't work if they were just working ???
Old 12-12-2010, 10:43 PM
Maybe one side wasn't turned all the way as you thought. Maybe one side let loose if so either side will turn. Jack up the truck, lock in one side and see if the axle turns by hand while turning the tire. If so unlock and do the same thing on the other side. If one side didn't lock in you found the bad hub. If they both work then they probably weren't lock in completely or the diff is bad internally.
Old 12-12-2010, 11:18 PM
Muktown's Avatar
Im guessing you just didn't have one of them fully engaged. And you had your girlfriend checking it out just remember only one side will spin so if she was on the driver side maybe the passenger side was spinning? If you want take the hubs apart and have a look see greasing them never hurts anyway but im guessing one wasn't fully engaged. They could have been iced up and you thought they turned to the stop but maybe they didn't turn far enough. Just throwin possibilities out there
4x4 Locking Hubs Thermoss 1999 to 2016 Super Duty 17 11-04-2016 02:28 PM
F150 Stuck in 4wd hi black98f1504x4 Offroad & 4x4 14 06-28-2013 04:24 PM
reverse Sensing System GunnyBeaty Excursion - King of SUVs 22 06-07-2013 11:04 AM
Manual 4x4 wont disengage dr1 1987 - 1996 F150 & Larger F-Series Trucks 20 01-22-2012 06:14 PM
I'mma need some help fixin lingering problems Lathan Stanley 1994.5 - 1997 7.3L Power Stroke Diesel 25 09-23-2011 09:40 AM
Tags
04, 1999, 2000, drive, engaging, expedition, f250, f350, ford, four, manual, powerstroke, quit, wheel, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
