replace clutch master cylinder - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-11-2010, 08:58 PM
novakp2 novakp2 is offline
novakp2 is starting off with a positive reputation.
I have a 2002 Ranger that I'm installing a new clutch master cylinder.
Although I removed it in an unconventional way I have a new one to install.
Does anyone know haw the push rod goes into the cylinder. Do you just force it in or do you need to take the cylinder apart to install the push rod?
I'm just on a break now and I'm in the middle of this.
Thanks for your help.
Old 12-11-2010, 09:07 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
if its like my 94 it will just pop in when you get the maste bolted in and hook the rod up to the pedal or just before.
Old 12-12-2010, 06:01 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
make sure you bleed the MC while it is out of the truck unless you bought a prebled one
new guy needs help with clutch and slave cylinder - Ford Ranger Forum
Sourcing Clutch Master Cylinder kellen302 1987 - 1996 F150 & Larger F-Series Trucks 3 01-29-2016 02:11 PM
bout to order master cylinder newguy399 1987 - 1996 F150 & Larger F-Series Trucks 3 10-26-2015 06:54 AM
Finally !! Hydraulic clutch bleed squirrel64 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-26-2014 07:07 PM
Clutch master cylinder push rod question WarOzz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-30-2012 02:11 PM
Clutch master cylinder removal jimkfish1 1999 - 2003 7.3L Power Stroke Diesel 5 03-29-2006 09:29 PM
Tags
2002, 94, change, clutch, cylendar, cylinder, f150, ford, install, installing, location, master, ranger, remove, rod, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
