1984 transfer case shift pattern
Does the 4x4 light come on when you're in the "first" position? In the "first" position, you can hop under the truck and try to spin the front driveshaft. If it doesn't budge, you're in 4H. If it moves easily, you're either in 2H or neutral. Try to spin the rear driveshaft at that point, easy = N, won't budge = 2H.
This, of course, assumes you have manual front hubs and they're in the free position.
The transfer case is an NP208f . The tag on the front axle says 3.54, which I am assuming is the 8.8" and the rear end has no tag. Both have 10 bolts on the housings and the pan for the trans is a large square with a smaller square...no tags on it. Wish I could figure out how to post pics. The truck is an automatic with a 300 6cyl. Manual locking hubs which are free right now.
See if this helps you:
User Gallery & Picture Display Help - Ford Truck Enthusiasts Forums
You're getting there with the pictures.
BTW there's a Testing forum here where you can try this stuff out all you want:
Testing..... - Ford Truck Enthusiasts Forums
I made the other photos thumbnails on purpose so they would load fast, thanks for the help! Figured the experts on here could identify right away no matter how small the pic. Thanks for the info...so the pattern on the np208 is 2H/4H/N/4L? Didn't seem right. From a little searching of these posts, sounds like the np208 set up with the 8.8" axle is not the best set up. I love the 300 6cyl with a 4x4 though, mild off road and hunting. My 1974 F100 2wd has a 351C (yes its a cleveland from a 1971 montego)built up to snap necks so I don't mind the slow and steady 84 when I go camping/hunting. Sure hope the C6 with the NP208 and 8.8 is somewhat tough...my F100 sure is.
fishfreak101
19
10-15-2016 09:29 PM
RageOfAntioch
05-31-2016 11:47 AM
Ruffasacob
02-17-2016 09:15 AM
twinpeaks
01-30-2010 06:28 PM
