Losing fluid, but where? - Ford Truck Enthusiasts Forums
Old 12-11-2010, 06:31 PM
tunaman tunaman is offline
tunaman is starting off with a positive reputation.
I seem to be losing fluid out of the E40D trans in my 91 E350 diesel. The problem is, I cant find where. Awhile back I replaced the filter and pan gasket and when I did that I cleaned off all of the road grime on the bottom of the trans. It is all still clean so it is not leaking from the pan. I also checked all of the tubes going up to the radiator and there do not appear to be any leaks. All of the connections are clean and do not appear to have any leaks. Further, the ground under where I park my van has been quite clean with no recent leaks. But, I am losing fluid. Where could it be going?
Old 12-11-2010, 09:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The only two places it can go is to leak on the ground or leak into the radiator through the in tank cooler.
Old 12-12-2010, 03:59 AM
So since I cant find a leak to the ground it stands that it must be leaking into the radiator. How do I tell? Is there a test I can do on the radiator?
Old 12-12-2010, 04:16 AM
Also, this is making me wonder about other things. If there is a leak in the lines into the radiator, that would cause a reduction in fluid pressure for the trans, right? So is it possible that it could cause other issues such as problems shifting with overdrive?
Old 12-12-2010, 07:03 AM
With the radiator cold you remove the radiator cap and see if there is oil there.
The leak can be small enough that it doesn't measurably reduce the pressure. Or it could be really big, but you would know that quickly. It would overfill the radiator and empty the transmission.
Old 12-12-2010, 11:09 AM
Well emptying the transmission basically is what has happened. The problem is that it turns out that my heater core busted a leak as well. So what I thought was rain water in my floor board turned out to be radiator fluid. Have the heater core ordered and I will get it replaced here pretty soon, but I guess until I do that, I wouldnt be able to tell.
Goop in the radiator (loaded info and question) 3KP Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 10-17-2016 07:17 PM
Mystery fuel leak... or oil? paddler 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-18-2012 10:31 PM
C-4 Transmission - Forward gears gone Jim Pivonka 1967 - 1972 F-100 & Larger F-Series Trucks 24 07-18-2010 08:01 AM
Question about changing transmission fluid E4OD JBronco 1978 - 1996 Big Bronco 8 02-08-2005 08:25 PM
1997 E150 Coolant Leak Dennis of KC 1968-2013 Full Size Vans 10 11-25-2003 01:29 PM
Tags
fluid, losing, radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
