1976 dually wheels - Ford Truck Enthusiasts Forums
1976 dually wheels
Old 12-11-2010, 06:23 PM
Rusty's92's Avatar
Rusty's92 Rusty's92 is offline
Rusty's92 is starting off with a positive reputation.
1976 dually wheels
Does anybody know where i can find dually wheels for a 1976? I need the 16" that take the acorn style lug nuts. I've been searching and haven't been able to find anything. I'm looking for the one piece wheels and not the split rim. Everything i've found is either 16.5" or hub piloted. My old split rims have seen some better days and i'm looking to replace them.
Old 12-11-2010, 08:34 PM
RustyHighboy RustyHighboy is offline
RustyHighboy is starting off with a positive reputation.
I had a set off about an '88 f350. I'm not sure what year they went away from the acorn style but they did use them on later models so you could check newer trucks as well.
Old 12-11-2010, 08:50 PM
Rusty's92's Avatar
I've been looking for any year, Ford used them for a few years. I've even looked at some trailer wheels. I know they have to be out there. Just need to dig some up.
Old 12-11-2010, 08:58 PM
akforceten's Avatar
akforceten akforceten is offline
akforceten is starting off with a positive reputation.
i have 76 dually rear end under my bumpside and i used the style without the acorn nuts .you just make sure you get the ring so you can use acorn nuts
it will make finding rims easier
Witty73's Avatar
Witty73 Witty73 is offline
Witty73 is gaining momentum as a positive member of FTE.
They are tough to come by. Other manufactures used the same wheels, so dont limit your search to just fords. it took me about 7 years to find a nice set of 6 to replace my split rims, and once I did, it cost me 25 bucks per wheel.
Old 12-11-2010, 09:11 PM
Rusty's92's Avatar
I've seen those rings, i wonder if that would work with my simulators. I'll have to look into that. I've searched chevy but they are mostly 16.5". I bought two off a 79 in the bone yard, they were beautiful. Still can read the stamped part number with the ford symbol. $50 a piece for those. I put them up front and left the split rims in the back. I feel a lot safer now. Just need four more.
Old 12-11-2010, 09:20 PM
akforceten's Avatar
they should i don't see why not .i had to run chevy rims up front because the wheel adapter came from a 95 chevy 1 ton dually 4x4. ford has a bigger opening then the chevy dually wheel .
Old 12-12-2010, 07:05 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
I feel bad for you I have so many of those lying around its not funny and the junkyards are packed with them. You also can't use them from a GM product with the small diameter hubs. Look at older GM , Dodge (Yes the new ones still use the same pattern) and ford trucks up til 97 and E-series up until now. You can score some pretty nice rims of a newer E series with DRW or any Dodge DRW truck.
Old 12-12-2010, 05:29 PM
lostinfords's Avatar
lostinfords lostinfords is offline
lostinfords is starting off with a positive reputation.
these won't work..hub eccentric vs. lug eccentric..you need these, I just sold a set of 4 to a guy in Wyoming, I do have a set of 4 16.5 duallie rims from a 78
Old 12-12-2010, 09:18 PM
akforceten's Avatar
why not? they are working just find on my truck for the last 7 years
Old 12-12-2010, 09:26 PM
luck?? ...are the rims 'locking' into the hub? are those rims that you have in the pic flat or have the convex/concave surface that acts as a lock? they look like the ones that I have on my 88 f350
Old 12-12-2010, 09:40 PM
Witty73's Avatar
didnt know there was such a difference. I bought 6, and havent gotten around to putting them on. Was going to wait until the bias ply tires on my split rims are shot. Better look at what I got.
Old 12-12-2010, 09:48 PM
akforceten's Avatar
the fronts are flat with lock ring ,the rears are the same . bought the rears from les shwaub
Old 12-12-2010, 09:51 PM
Witty73's Avatar
all 6 of my split rims are flat. I bought 6 flat 1 piece to replace them. Thought it was pretty straight forward.
Old 12-12-2010, 11:57 PM
if you get a chance can you post up some pics of what you have, I would like to see the detail of them, always open to learn someting different, wonder if that flat ring acts as the locking feature that is in the rim itself, there is a difference in between the newer and older budd/duallie rims, cause my 88 rims won't work on my 77 and vice versa
stock excursion wheel on front of dually...ideas ufvj217 1999 to 2016 Super Duty 26 12-06-2015 05:02 PM
53 Merc wheels Vinford 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 09-27-2014 06:55 PM
Front spindle conversion? Butchashop 1967 - 1972 F-100 & Larger F-Series Trucks 0 08-04-2014 10:06 AM
New tire questions for F350 flatbed John in Bismarck 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-13-2013 09:16 PM
1973 ford f350 dump truck bruali 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-09-2012 12:30 AM
Tags
16, 165, 1976, 76, acorn, adapter, duallie, dually, ford, hole, lug, nuts, rims, ton, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
