How do you prime the HPOP ? - Ford Truck Enthusiasts Forums
Old 12-11-2010, 05:05 PM
sullyt28 sullyt28 is offline
sullyt28 is starting off with a positive reputation.
Doing a long block build up. Told I need to prime the HPOP. Any ideas on how to do this with conventional tools ? Oil cooler installed or need to leave off ?
Also, is it okay to clean the ICP with carb cleaner and re-use ?
Old 12-11-2010, 06:40 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
When mine was replaced at the dealer they just cranked it untill she fired up. After looking for leaks and leting her warm up they went on a drive and let her shift through all of the gears at full power.
No idea on the ICP though.
Old 12-11-2010, 06:44 PM
npccpartsman's Avatar
npccpartsman npccpartsman is online now
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
You need to fill the HPOP reservoir before you put the oil cooler on. It will save you a LOT of wear and tear on your starter. I wouldn't clean the ICP with anything. I'd gently clean the screen. If you got a new STC fitting for the HPOP a new screen should come in the kit.
Old 12-11-2010, 08:24 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
I filled mine then unplugged FICM and cranked it for 30 seconds or so.
Old 12-11-2010, 08:38 PM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Quote:
Good idea!
Old 12-12-2010, 07:53 AM
In the instructions with the long block they clearly state to prime the HPOP as they don't want the motor spinning over and over. I guess to avoid pre mature wear ?
Just curious if anyone has done this or if it is needed ??
Old 12-12-2010, 07:59 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
IMO that just means to fill the valley of the engine (and be very clean when doing it).
Old 12-12-2010, 08:49 AM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Quote:
pretty much what mark said.
the engine wont start till it has high side oil. thats made by the hpop anyway.
Old 12-12-2010, 09:07 AM
Okay thank-you. BTW - How many litres of oil go into the valley ?
I guess I better upgrade the STC fitting as well. Truck is an '05. Been looking for a thread on part # and how to replace. Appreciate if anyone could forward a link.
Old 12-12-2010, 09:14 AM
cheezit's Avatar
.89qts of oil go in to the sump.
Old 12-12-2010, 09:56 AM
I believe thats about 2 litres. Thanks Cheezit.
Found a thread thanks to Bismic on the stc.
STC fitting install - Ford Powerstroke Diesel Forum
Old 12-12-2010, 09:59 AM
cheezit's Avatar
http://www.ford-trucks.com/forums/97...on-a-pump.html
another thread maybe of use to you
Old 12-12-2010, 10:04 AM
Actually that's about 8/10 of a litre. 1qt=.967 litre IIRC
Old 12-12-2010, 12:28 PM
Rubenk's Avatar
Rubenk Rubenk is offline
Rubenk is starting off with a positive reputation.
The low pressure pump will still be lubricating the motor, it takes the HPOP pumping oil to actually start it.
I say just keep cranking till it starts, in about 15-20 second bursts.
hpop reservoir loosing prime rjrandy96 1999 - 2003 7.3L Power Stroke Diesel 0 05-19-2016 08:10 AM
HPOP Prime Amount?? IT STARTED!!!!!!!!!! syjl 1994.5 - 1997 7.3L Power Stroke Diesel 14 01-26-2016 06:00 AM
Small Block oil pump priming Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 08-06-2013 03:30 PM
Oil Pump Priming Tool? TOPS Oil & Lubrication 18 10-24-2009 04:36 AM
Rid of major problem, now have a minor one...Hpop needs primed maybe??? Todd525 1994.5 - 1997 7.3L Power Stroke Diesel 1 02-11-2007 08:40 PM
Tags
60, 60l, 73, 73l, diesel, engine, f350, ford, high, hpop, location, oil, powerstroke, pre, pressure, prime, priming, pump, reservoir
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
