hard start after warmed up
need help with trouble shooting
ok I have a 2003 6L with about 134k on it
for the most part runs great but a few weeks back it start missing a little when cold ( southern AZ so cold isnt that cold ).
Its done this before about once a year I add some techron to the fuel tank and it clears right up, but this time I also changed the oil which sometimes makes it worse for a week intill the oil is broke down a little ( dont know why its just how it is maybe 15-40 is a little thick in the winter here??) anyway well this time it got worse and didnt clear up, so after a week I drained the oil ( keep in mind i just did a oil and filter change ) so I drained oil and put 5-30 in to see if it would help in winter.. man it got way worse , started cold but almost would not restart after it warmed up .. very hard start had to hold the key down, try a few times hold down the gas pedel and it missed , etc but started so i drove it home and drain the 5-30 out and refilled with my 15-40 I took out.
( had put it in a clean container ) anyway, started running pretty good it would now start right back up after it was warmed up. but now it did it again today after i drove it about 5 miles , shut it off and was in a friends house for about 10 to 15 mins went out and it didnt want to start ?
So what would make this truck start fine COLD, ( miss a little till warmed up ) then make it not want to restart with warm engine. ?
also when i left my friends house intill i got about half way home it was still heasting when shifting ( auto trans ) then once warmed back up ran fine ?
should I drain the oil again and refill with new 15-40 to make sure there is no trace amounts of the 5-30 ? sound like a injector to you ?
i am not telling you that this will solve it but i switched from 15 40 to 10 30 and i think it helped my starts. i also wait until i hear the vaccumm pump go off before i start(sounds like a small growl from under the hood)or i watch my insight and when it starts showing the engine reading i hit the starter.
I had a similar problem and I put a BB from a BB gun under the fuel pressure regulator spring (there is plenty discussion here on the forum about that) and it worked. I speculate when the engine gets up to temp the fuel thins down a bit and squeezes by the regulator easier, thus causing a little lower fuel pressure on start-up. I would also be careful, the BB could cause too much fuel pressure and that could damage your injectors. There are people here that know more about that than I do.
there also was a clicking noise under the dash a few weeks back i could never find. I cleaned the battery charge line and it pretty much went away.
Its not exactly cheap, but this is the bestway to go IMO:
Quadzilla Performance Recon XZT Digital Gauge - Truck Customizers
