wipers won't park - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
wipers won't park
Old 12-11-2010, 03:14 PM
LV390 LV390 is offline
LV390 is starting off with a positive reputation.
wipers won't park
Anyone have a wiper park problem fix? They won't park correctly and in intermittent they still work butdon't park in correct spot. The next cycle they just continue after parking in wrong spot. Linkage problem maybe?
Old 12-11-2010, 05:05 PM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
Has anything been done to the truck recently?
If the wipers have never been disconnected then I'd say something in the linkage is bent or being restricted in movement.
If the wiper arms have been removed then they just need to be relocated. That might solve your problem even if they haven't been removed.
Old 12-11-2010, 05:23 PM
carltonwebb's Avatar
carltonwebb carltonwebb is offline
carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.carltonwebb has a great reputation on FTE.
I have seen the one of the plugs come loose at the wiper motor itself. All 3 speeds will work but it will not park and intermittent will be funky
Old 12-11-2010, 06:45 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Its worth taking of the plastic piece and having a look at the linkage IMO. I had a piece of ice go down in mine and bend the linkage. It bends surprisingly easy.
Old 12-11-2010, 09:09 PM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
I had a wiper motor go bad that caused this...
No intermittent wipers- wipers will not park after using washer?? No cost fix!! phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 50 11-18-2016 11:22 PM
Wiper control isn't working correctly RandomNewGuy Excursion - King of SUVs 6 06-28-2015 01:23 PM
Wiper Parking 82f100460 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 04-01-2012 04:30 PM
1999 F-150 Wiper problems skip17 1997 - 2003 F150 4 04-06-2011 10:45 PM
Wipers won't return to park position Grannygear 1997 - 2003 F150 2 01-10-2009 01:32 PM
Tags
1978, 79, 87, 99, aftermarket, dont, f150, f250, ford, motor, park, windshield, wiper, wipers, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
