'05 f250 6.0 no oil flow/pressure - Ford Truck Enthusiasts Forums
Old 12-11-2010, 12:33 PM
jeffrsi jeffrsi is offline
jeffrsi is starting off with a positive reputation.
Hello All. My truck died seconds after a warm restart. No previous symptoms. Check Gauges message. After long crank..no idiot gauge pressure. pulled oil filter and cranked... no flow, no oil. pulled LPOP regulator. It all just kinda slid out of the bore like it wasn't stuck. No oil came out with it. Crank with regulator out... not a drop of oil. Pulled LPOP...nothing notable, no grooves, very minor markings actually.
Am I missing something or is my next step to pull the pan? Can the pan clear without jacking the engine?
BTW it does have oil in the pan... just saying.
102,000 miles
Appreciate any help, thanks
Old 12-12-2010, 12:35 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to 6.0L Powerstroke Diesel Forum.
Old 12-12-2010, 02:03 AM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
Did you check your oil level? Do notice any oil leaks? Also I think you have to have at least 500psi of oil pressure on the injectors to get it to crank over. My oil pressure idiot light usually doesn't even move until after the truck is started. And somtimes shows nothing until its in. Gear.
Old 12-12-2010, 08:49 AM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
^^^ I agree. My gauge will do the same.
Old 12-12-2010, 09:31 AM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
102,000 miles
Have you checked for codes?
If you decide to pull the pan:
You don't have to pull the upper pan, but it might be wise to remove it and replace the gaskets. The job requires an upper pan gasket, lower pan gasket and a pick up tube o-ring.
Removal of the outer shroud is all that is necessary. Remove the motor mount nuts and lift the engine. Make sure to wedge something like a block of wood or large sockets between the frame and motor mounts for safety.
Unbolt the pan and drop it down. Then drop the pick up tube in the pan - the pan will not clear with the tube in place. Then slide the pan out the rear under the transmission.
Old 12-12-2010, 10:42 AM
Thanks for the responses...hopefully the tube will be laying in the pan. Why else would I have no low oil pressure if everything else looks fair.
Unreal04... yep it's got oil. you gotta have low pressure oil before you can have high pressure oil. yes there are oil leaks... it's a 6.0. My idiot gauge always came up on crank... thats why this has got me so baffled... from running trouble free to zilch in 15 seconds
Old 12-12-2010, 10:46 AM
Bismic, there were no codes. Just the "check gauges" on the message center as it died
Old 12-12-2010, 10:56 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
The check gauges light would be from no oil pressure on the idiot needle. Don't remember, but does the gerotor have some kind of key to drive it and maybe it sheared off??? Did you crank the motor with the gerotor in place, cover off to see what it was doing?
Old 12-12-2010, 08:15 PM
No I did not crank it without the cover. The gerotor does have what looks like 1/4 key slots but also has large flats on either side. the crank is machined with flats to match. No way it's spinning unless its broke in half.
There is some slop in the old and new crank mounted "gear" but its a rotation thing and not a wobble.
Old 12-12-2010, 09:04 PM
Now that I went back and read the manual I see. The gerotor gears are only like $30 so as long as you're there replace them.
I don't understand what you mean by slop between the "old and new". There shouldn't be any slop to speak of.
Old 12-13-2010, 05:16 AM
how to explain... put a sprocket on a shaft, it fits good but without a key it can spin on the shaft. Or if the key was worn it might have this movement
The flats in the gear are bigger than the flats on the shaft in this case. the "slop" is a spinning movement. It's ever so slight but there is movement. Both the old gear and new have this movement.
Old 12-13-2010, 06:02 AM
I understand what you're saying now. I didn't know that you'd already installed a new gerotor set. I suppose you've already reinstalled the pump cover and tried to see if it would pump oil to the filter with the new gerotor in it?
I'm sorry if I maybe come off to you as ignorant, but it's been 4 years since the last time I put in a gerotor pump MYSELF. I'm just trying to help you solve your problem with the least amount of work involved on your part and I have to ask questions.
Old 12-13-2010, 10:44 AM
hey I appreciate the questions and input... makes me feel better about laying under it talking to myself.
Way I look at it is ... if I can't explain it then I didn't look at it good enough in the first place.
I put the pump and cover on and it didn't change anything. New regulator too.
Everybody keeps saying 30 - 35 bucks for gears...I paid $535 for gears, cover, seals and the pressure regulator. Should I throw the old one at somebody?
Nothing else to report at the time... had to actually go to work so it's sitting for a day or so
Old 12-13-2010, 11:48 AM
Wow--you got a whole new front engine cover and everything. I'm not sure that you can get the pressure regulator any other way though. I know you can get JUST the gerotor gears for less than $35. I replace (or have replaced) mine everytime I do anything major. Cheap insurance.
One thing about the used front cover though.....it should be very saleable to someone with an 03 or early 04 motor since it has the bigger/upgraded water pump cavity. They are fairly popular.
Old 12-13-2010, 01:42 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
i remember a post awhile back with someone that had this problem.ended up being a stc fitting.there was so much oil bypassing the broken fitting that it wouldnt build low oil pressure.you need to make sure its not a stc fitting before you go any further.
No oil pressure! LPOP or something else? Bubba Jones 1994.5 - 1997 7.3L Power Stroke Diesel 10 04-24-2016 12:52 AM
Need help diagnosing a low oil pressure problem cschulz135 1999 - 2003 7.3L Power Stroke Diesel 4 04-09-2015 08:58 PM
6.0L LPOP problem mudsmokinstroker 6.0L Power Stroke Diesel 3 04-15-2014 06:43 PM
no oil supply from lpop plumb-evil 6.0L Power Stroke Diesel 12 03-02-2014 09:23 PM
Low Oil PSI and HPOP Failure dieseldrivr 6.0L Power Stroke Diesel 3 12-09-2009 10:11 PM
Tags
05, 2007, 60, crank, f250, filter, flow, ford, light, lost, low, oil, powerstroke, pressure, recommended
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
