Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-11-2010, 11:02 AM
unreal72 unreal72 is offline
Garage is empty, add now
unreal72 is starting off with a positive reputation.
Long shot
I know it's a long shot but maybe someone else has the same issue.
I have a loud rattle coming from my passenger seat. it seems it is do to the natural vibrations of the truck vibrating the chair. it is so annoying i cant stand it!
anyone else have this issue?
thanks in advance
  #2 (permalink)
Old 12-12-2010, 12:22 AM
kennisonxgs kennisonxgs is offline
kennisonxgs is starting off with a positive reputation.
Does it happen if you have a passenger?
  #3 (permalink)
Old 12-12-2010, 11:34 AM
Quote:
No it doesn't...I can actually reach over while driving and put pressure on the upright portion of the seat and the rattle stops.
  #4 (permalink)
Old 12-12-2010, 12:15 PM
That's just like mine. I recall someone on this board had their seat frame replaced from a similar issue. Also, if it helps, if I pull up the back-front seat adjuster lever, the noise goes away as well. I no longer have warranty and definitely don't want to pay for a fix.
Maybe you could try searching for the other person's seat rattling noise. I'm on a mobile connection and can't help with that.
  #5 (permalink)
Old 12-13-2010, 11:17 AM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
May sound crazy
Have you checked to make sure the seatbelt isn't just banging against the pillar?
  #6 (permalink)
Old 12-13-2010, 11:39 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
The plastic on the seat belt clip does rattle on the pillar if not posistioned correcty. But, there is a rattle under the seat. It has to do with the springs and lever that moves the seat forward and backwards. I had to look under with a light and hit the seat with my hand until I found the noise, then greased up or put felt stickers on the area that was causing that. Took 20 minutes.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #7 (permalink)
Old 12-13-2010, 06:40 PM
give it a try
Quote:
Thanks, I will give it a try. Today might be a bad day though, -9 deg. with 6 inches of snow here in MI.
  #8 (permalink)
Old 12-13-2010, 11:25 PM
My expy could use some stickers then.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
