Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-11-2010, 06:59 AM
JetFuelBurner JetFuelBurner is offline
2000 Ford F-250
JetFuelBurner is starting off with a positive reputation.
Starting problems...
2010 Expedition EL, 38k miles.
The wife experienced some stumbling of the engine pulling out of our subdivision. Intermittent. I put in some super unleaded and fuel injector cleaner. Did a road trip from GA up to IN and didn't give it another thought.
Well, last week she's coming home from work and tries to start the truck. It runs for a second and dies. Subsequent starts, it tries to start but does not get going. I have her on the phone and tell her to work the gas pedal and floor it when it begins to run. It clears up after about a minute and runs fine.
I experienced this once or twice in my 2000 F250 once or twice but once running, it didn't do it again for a year or two.
Her Exp. has done this repeatedly for a week (i've been out of town). I am putting in the super concentrated fuel injector cleaner and a full tank of high test again and going to the auto parts dealer to put the reader on it.
There were no check engine lights or messages of any kind.
EGR valve or 02 sensor? That's my first guess but I would have expected some kind of error code or check engine light...
Thoughts???
  #2 (permalink)
Old 12-11-2010, 08:09 AM
gddyup's Avatar
gddyup gddyup is offline
Garage is empty, add now
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
If it were EGR related or O2 related, I would expect a code especially in a no start condition. If it were me having this issue, I would probably pull codes oike you referred to and if there was nothing there I would then most likely throw a fuel filter at it. A fuel filter would be short money.
__________________
Firefighter/EMT IAFF Local 4392
"I've done a fair share of stupid things in my life, a couple of which should have put me in my grave. But here I am typing away as if I had a brain." - Craig Wilson
  #3 (permalink)
Old 12-11-2010, 08:56 AM
2000 Ford F-250
Quote:
Originally Posted by gddyup View Post
...I would probably pull codes oike you referred to and if there was nothing there I would then most likely throw a fuel filter at it. A fuel filter would be short money.
Exactly what I was thinking. No codes. Started right up for me this am (go figure!). I'll put a new fuel filter in it and see what happens.
  #4 (permalink)
Old 12-12-2010, 08:57 PM
BigMick BigMick is offline
BigMick is starting off with a positive reputation.
I had the same type of problem using gas from a" knock off" station. Filter clogged at about 25k.
Mike
  #5 (permalink)
Old 12-13-2010, 10:38 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I would change filter, and remove battery cable for 20 minutes then try that. I would stop using fuel system cleaner for the time being.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #6 (permalink)
Old 01-05-2011, 04:13 PM
2000 Ford F-250
Dealer did a computer reset that appeared to cure the problem. About 2 weeks later it did it again. Typically does it when the fuel is below 1/2 tank.
Picking up a new filter tonight. We'll see if I can do this without breaking the infamous little blue clips!
Tags
2004, 2007, expedition, ford, forums, navigator, problem, problems, relay, start, starter, starting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
