1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 ford F250 RPM Wiring Diagram
Old 12-11-2010, 02:56 AM
Mike-11's Avatar
Mike-11
Mike-11 is offline
Does anyone know how the RMP cluster wiring is set up. My 06 Ford F250 5.4 L RMP drops after I turn on my defrost or heating unit. It never drops in summer when I turn on my AC. Two things happen when I drive after 15 minutes of high heat. One, when I hit some bumps the needle will drop to zero. Also when I turn off the heating unit, the needle will also drop.
Where should I start to look for a lose wire under the truck or dash. Again if anyone has a diagram I could check for a lose wire or a bad ground.
One more thought. Is the the heating unit on the dash faulty?
Thanks,
Old 12-11-2010, 11:11 AM
bpounds's Avatar
bpounds
bpounds is offline
The instrument cluster is all microprocessor controlled and is on the CAN bus. So it is not a matter of looking for a loose tach wire. You could pull the cluster and check all the ribbon connectors, and at the same time check all the grounds. But I wouldn't get too hopeful over that.
The '05-'06 is known for cluster problems. Usually it is the speedo that reads bad. I have not heard of one doing what you are describing.
Old 12-11-2010, 01:56 PM
Mike-11's Avatar
Mike-11
Mike-11 is offline
I know that is the weird part. I fix my speedo on the back of the axle (VSS) unit. The RMP I don't understand. It only happens when I turn on the heat to warm up truck and to defrost my windows. I do not lose any power when this happens
Again, after 15 minutes of heat the needle drops. Or when I hit a big bump. Thats why I thought I had a lose wire or the heating/ac unit in the dash was faulty.
That's why I was hoping someone had a wiring diagram on the RPM. I guess it's the cluster, I just wanted to make sure before I replace it. I was hoping for a easy fix.
Thanks
Georgia Lynxon
Escape & Escape Hybrid
08-01-2017 08:40 AM
Addison3000
2004 - 2008 F150
10-19-2016 05:20 PM
kevbits
41
03-21-2016 07:02 PM
Ex-ChevyOwner
10-11-2015 10:18 PM
Hank99
08-23-2012 12:15 PM
Quick Reply: 2006 ford F250 RPM Wiring Diagram
